Old 10-17-2003, 05:57 AM
The ONE The ONE is offline
Intake Manifold PROBLEMZ PLZ HELP!!
i have a 92 lx civic and i had it miniswapped for a jdm d15 b engine. I just put vtech harnesses on about 2weeks ago , but when me and my friend did that we broke the 02 sensor on my stock intake manifold. so my oil was burning rich, So i then bought a stock si manifold for $20 and put that in. The problem is that my vtech is working but my car idles now. It idles back and forth to 2200 rpms and back, and back again. It keeps going back and forth. Sometimes it just stays at 2200 rpms, it changes every now and then BUT it never goes back to normal jus IDLE,IDle,and idles! Now i know it has something to do with the maifold since this problem started when i put tha intake manfiold in. I just checked the throttle and it has nothing to do with it. Also im using the same throttle body from ma old engine.
PLZ HELP!!!
Old 10-17-2003, 01:23 PM
joey h. joey h. is offline
i've personally never seen an o2 sensor on a intake manifold. but it also sounds like your idle air control valve is bad
Old 10-17-2003, 02:20 PM
Jeff C's Avatar
Jeff C Jeff C is offline
Re: Intake Manifold PROBLEMZ PLZ HELP!!
As said above, the fluctuating idle is usually attributed to the IACV on the back of the intake manifold. Put the IACV from you old IM onto the new IM, then see what happens.
-1989 Honda CRX Si, B18A Pic FOR SALE
-1998 Honda Accord EX Sedan 5spd
-1981 Chevrolet Silverado, shaved and bagged Pic
Old 10-19-2003, 03:37 AM
Smile tHNX FOR THE INFO
tHNX FOR THE INFO BUT I FOUND OUT WHAT the problem is. I fogot to put one of those nuts that connects to the head on the gasket and the air was leaking out of it. It was pretty hard to reach but i got it. But i jus checked my radiator and i found out i had plastic hose particles and a 20 fuse in ma hose line.WTF!!! The dumbass b4 me i dont know how he did it but he managed to put a fuse in ma radiator to the hose line. O Well gotta check ma head to see if anything got in there thats not supposed to be.
thnx
Old 02-12-2004, 12:26 AM
ras_2680s ras_2680s is offline
PLZ HELP!!!
Hi. I have the same problem too I have a 1995 acura integra RS I just put in a new edlbrock victor x intake manifold. I can start the car but when I start the car It idles from 1300 to 1600 back and forth back and forth. I try warming up the car but it did not work it still idles back and forth. Can you tell what wrong. I clean the IACV and it still idles. However, there is a leak between the header and the cat. Do you think that can be the problem.
Intake Manifold Gasket End Seals bjaymo3 Grand Prix 5 07-30-2010 08:29 AM
Replace Intake Manifold Gasket Stammtra Cougar 4 07-20-2010 12:13 AM
2002 2.7L Intake manifolds ksparticuspa Intrepid 1 07-02-2010 02:25 AM
Intake Manifold/Header/Exhaust Help Kinked210 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 02-11-2004 12:40 AM
Venom Intake Manifold Problem, please help sx250xl Off-Topic 1 12-03-2003 03:42 AM
