Go Back   Automotive Forums Car Chat > Honda > Integra
Old 10-16-2003, 07:09 PM
jspit21 jspit21 is offline
Wink ls port&polish
what would be better, to port and polish the stock ls head or get a type r head?
Old 10-16-2003, 07:28 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
it depends on what you are tring to do. Turbo,nitrous,supercharger,all motor?
Old 10-16-2003, 08:15 PM
Re: ls port&polish
trying to go all motor
Old 10-17-2003, 12:04 AM
tegdude tegdude is offline
then you want the type r head
Old 10-17-2003, 08:34 AM
00tegra 00tegra is offline
if you are going to go through the trouble of port and polish, you might as well go the whole way and get the type r. that is what i think i am going to do.
Old 10-17-2003, 03:24 PM
boosted331 boosted331 is offline
N/A, turbo, nitrous, blower, whatever you want to do the ITR/B16 head is better than the LS. It flows better out of the box, flows more ported, and makes more power. And if anyone says go LS head if you go turbo because of overlap, shut up. If LS heads were so good for turbo how come an LS/Vtec turbo makes a boat load more power than an LS turbo? It ain't because of half a point more compression.
Old 10-17-2003, 06:44 PM
sameintheend01's Avatar
sameintheend01 sameintheend01 is offline
Send a message via AIM to sameintheend01
Re: ls port&polish
Clear Corners
Front and Rear Strut Bars
Cold Air Intake with K&N filter
Iridium Spark Plugs
High Performance Plug Wires
High Flow Cat (unistalled)
Cool high/low beam lights
All around slotted and AEM pads
Old 10-17-2003, 07:22 PM
93weed_eater's Avatar
93weed_eater 93weed_eater is offline
Send a message via AIM to 93weed_eater
the reason turbo LS/VTECs make more power than a Turbo LS is because of the VTEC....think about it.....think about it.....did it set in yet? and yes if you're going allmotor just go ahead and do the LS/VTEC but use the B16 head. you'll save a ton of money.
Old 10-20-2003, 08:36 AM
kittedb18bt's Avatar
kittedb18bt kittedb18bt is offline
Re: ls port&polish
this is a newbie post. u have been here long enough. you should know this by now. valve overlap is the reason why people do not like vtec with their turbo applications. compression is almost irrelevant. notice i said ALMOST. even if u change out the cams completely in the gsr, the ls has more potential. i will not go into other reasons why the ls is chosen over the gsr for FI. this has been argued over and over again in many posts. do a search beofre you make such a stupid response.
Co-Founder of AF V-Card Club
1999 Ford Mustang Cobra: Cobra R rims, Magnaflow CB.
"no way man...i saw an LS1 fight godzilla and the LS1 beat godzilla and it looked in the air and was like what do you think of that god and god was like bring it bitch so they fought and the LS1 beat god now the LS1 is god because its the greatest thing ever."
Old 10-20-2003, 08:42 AM
Re: ls port&polish
my previous post applies to u also. you should know better about valve overlap. to boost a lot-your cams need to have a high lift and short duration. for good NA apps-you would like medium lift and a very long duration. wow, and i used to respect you.
Old 10-20-2003, 03:18 PM
Re: Re: ls port&polish
Please oh Mr. Honda God, enlighten us HOW the LS is better. The head flows less, and has less potential to flow while ported. That's a fact. Having vtec lets you run more duration and lift up top (where overlap is NOT AN ISSUE BECAUSE THE MOTOR IS SPINNING FAST ENOUGH THAT HAVING SOME OVERLAP IS NOT GOING TO UNLOAD THE TURBO!!! ) to make more power but run a lower duration and lift profile for the low end so you still have enough power to drive around for a street car. Most full out race hondas are probably launching at 6000+ RPM's and would be running the vtec lobe permanently, but does that means they're going to the LS heads or LS blocks because they're better? No.
If you think you're the king shit when it comes to cams, keep thinking that. Call ANYBODY that makes turbo cams for ANY car and none of them will tell you that a very low duration cam is bad. Yes, overlap is bad, but there are other factors much more relevant to how much power your motor is going to make other than overlap. Call ANY reputable cam grinder that has been in the business long and has ground lots of turbo cams before, ask them what they think. They arn't going to grind you a 190/190 @ .050 .650/.650 lift cam because that would make fuck all for power. Call up cammotion 225 9266110 in louisiana, they'be been grinding cams for ever, ask them what they think. Call up murillo, bennett, holcomb, call up ANYBODY who has been in the turbo business for a while and see what they think.
Old 10-20-2003, 03:34 PM
Mendari Mendari is offline
Hello jspit21,
It looks as if you've started another good old fashioned Honda cat-fight. Meeoww. Let's start at the begining, how much do you want to spend and what do you want your car to do?
Old 10-20-2003, 03:44 PM
Re: ls port&polish
Originally Posted by Mendari
Hello jspit21,
I'm thinking of spendind around 3000 within the year. I didn't know if it would just be better to buy a turbo or to change my car to a manual. Would my car not be that much faster with a turbo because its an automatic or is it just the fact that the manual is more efficient
Old 10-20-2003, 04:10 PM
whtteg's Avatar
I would do one of two thing I would either sell the car before you out any money into it and buy a manual or go ahead and do the manual conversion. I think you will come out cheaper just selling the car and buying a manual. Then go from there. If you feel you have to have VTEC then buy a GSR if not the buy a LS. simple as that. Now I would suggest the LS if you are trying to keep a
$3K limit. B/c for $3k with the GSR you will be boosting 6-8psi and the LS you will be boosting 8-12psi, b/c with $3K you won't have enough money to build either motor's bottem end, and the LSwill be faster stock for stock. But the GSR will be fast and the turbo will work fine on it but you won't be seeing as mich boost as with the LS. Also LS/Vtec engines have to be done exactlly right when you are trying to boost them or bad things will happen. If you cannot find a reputable shop that has fdone lots of thesse and had no complaints then go for it but it is more risky and not really worth it IMO you are only getting a little more dispalcement with LS/VTEC so it does not out weigh the risk IMO
Old 10-20-2003, 06:36 PM
Re: Re: Re: ls port&polish
i did do some research, and if i may, i retract the statement about the duration the lift statement will stand though. you are quite educated, although i will not dismiss my response completely. this is a stupid argument-it is been covered many times and they always have the same outcome. u do win the argument with me, but i have always seen LS blocks and heads run faster than their vtec siblings.
