Old 10-16-2003, 06:50 PM
Lee Must Lee Must is offline
1995 S-10 Blazer, Ignition Locked
I shut my Blazer off and went to start it, but the ignition and steering are locked and I can't do anything.
Does anybody have any ideas that can help me?
Old 10-17-2003, 11:20 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: 1995 S-10 Blazer, Ignition Locked
Will the ignition lock cylinder turn?
If not, you could have something as simple as a worn key (have a new key cut from the lock codes available from your GM dealer...don't have someone duplicate your worn key...that defetes the purpose.) or you may need to replace the ignition lock cylinder
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 10-17-2003, 11:21 AM
GMMerlin's Avatar
I know stuff
Re: Re: 1995 S-10 Blazer, Ignition Locked
If you go to the dealer for your key codes, take proof of ownership with you and your drivers license...we don't give out that info or cut keys without it
GM WCT
PM Me for details
Old 10-17-2003, 05:14 PM
Thank you, I finally got a key to work I think it was an original, it works, but I can't the key out and the shifter won't work properly.
Old 10-19-2003, 12:56 PM
Brokebyford Brokebyford is offline
You may have a bad shifter cable.If you can't get the shifter all the way seated in the park position then the ignition cylinder will not return to the lock position and you won't be able to get the key to come out.Try holding the shifter handle with pressure toward the park position while turning the ignition off and if it's not bound up too bad you should be able to remove the key.
Old 10-19-2003, 04:22 PM
Re: Re: Re: 1995 S-10 Blazer, Ignition Locked
Thank You, I will try that next...
Old 10-22-2003, 12:23 PM
jenniferpace jenniferpace is offline
I can tell you exactly what it is, same happened on my 1997 blazer. Faulty ignition switch, there is a tech bulletin on it. Had to take mine to the chevy place, cost around $300.00!
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
