Old 10-16-2003, 05:34 PM
MoRsuS's Avatar
MoRsuS MoRsuS is offline
What exactly is torque?
What exactly is torque? what exactly does it mean when something states it has (eg) 230lb.-ft of torque?
Old 10-16-2003, 10:29 PM
454Casull 454Casull is offline
Re: What exactly is torque?
Torque is a force applied which tends to turn things instead of displacing them (i.e twisting a wrench vs pushing a box). Torque is measured by the force applied multiplied by the distance from the point of application to the turning point.
i.e. if I apply a force of 100 newtons on the end of a 30cm (0.3 meters) wrench, the torque is 30 newton-meters.
If an engine has 230lb-ft of torque, it means it exerts a force on the pistons such that the total torque transmitted through the crankshaft (remember the crankshaft turns because of the pressure on the pistons) is 230lb-ft, measured either at the flywheel or at the wheels. Usually at the flywheel, though.
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
Old 10-17-2003, 12:07 PM
MoRsuS's Avatar
great thanks man
