Old 10-16-2003, 02:45 PM
RedlyneAccord RedlyneAccord is offline
Send a message via AIM to RedlyneAccord
vtec controller
im looking into buying a vtec controller, but someone i know but one in his sohc and it does nothing. Are they made to work in sohc vtec cars?
Old 10-16-2003, 02:58 PM
Myjunkistight Myjunkistight is offline
Re: vtec controller
you only need a vtec controller if you have vtec.
ZC Crx ready for the HMT kit.
Old 10-16-2003, 03:09 PM
Re: Re: vtec controller
i have vtec, does it work in a sohc, my friend had a sohc vtec and it did nothing, not sure if they dont work with them, or if the people that put it in are stupid
Old 10-16-2003, 03:13 PM
Re: Re: Re: vtec controller
The only reason you would need a vtec controller is if you put a vtec engine into a chasis that had an ecu that didn't originally have vtec. Then you would need a vtec controller so that the engine would switch over into vtec at a specified rpm.
Old 10-17-2003, 02:34 PM
Jeff C's Avatar
Jeff C Jeff C is offline
Re: vtec controller
What vtec controller does he have, Apex'i VAFC, or something else.
Btw, you really dont need to be changing your vtec engagement on a stock car.
-1989 Honda CRX Si, B18A Pic FOR SALE
-1998 Honda Accord EX Sedan 5spd
-1981 Chevrolet Silverado, shaved and bagged Pic
Old 10-17-2003, 03:16 PM
boosted331 boosted331 is offline
Only reason you need a vtec controller is if you're running larger cams, in which case you should be running a standalone that can control vtec activation anyways.
Old 10-17-2003, 09:06 PM
B16EJ1's Avatar
B16EJ1 B16EJ1 is offline
Re: Re: Re: Re: vtec controller
Wrong, You need VTEC controllers for a couple things. As already stated, VTEC engagement will need to be modified w/ the use of aftermarket cams to attain the true potential of the cams. Also with an aftermarket ECU or reprogrammed, you can use a VAFC to tune the aggressive fuel map or push the VTEC cross-over back for the best gain seeing as most aftermarket programs puch the cross-over forward.
Old 10-18-2003, 03:52 AM
ChicagoK20 ChicagoK20 is offline
Banned
Re: vtec controller
i had a j-spec LS vtec SOHC with a vtec controller on it
so yea, they make em
Old 10-18-2003, 11:06 AM
Jeff C's Avatar
Originally Posted by ChicagoK20
j-spec LS vtec SOHC
Are you sure that you know what you are talking about?
Old 10-18-2003, 11:20 AM
Re: Re: Re: Re: Re: vtec controller
Yes I know that vtec controllers can be used for different things. I was just trying to point out that there is no point in getting one for a stock motor. I figured he might have swapped a vtec engine into his car and wasn't getting vtec because he had no way to get it to engage.
Old 10-18-2003, 07:37 PM
B16EJ1's Avatar
WTF is a SOHC LS VTEC? There is no such thing as a LS single cam.
