Old 10-16-2003, 01:42 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Which wire is positive/negative?
I have a 2000 hatchback and need to know which wire is positive and negative for the front speakers in the door. I either hooked up my Pioneers out of phase or they're shitty speakers.
Old 10-16-2003, 05:04 PM
whiteracer whiteracer is offline
Send a message via AIM to whiteracer Send a message via Yahoo to whiteracer
Re: Which wire is positive/negative?
the wires that connect directly to the speaker itself? Aren't the clamps on the ends different sizes and correspond to its size on the speaker? If it doesn't work, can't you just switch the polarity and walla?!
Name's David.
Old 10-16-2003, 08:26 PM
Ricochet's Avatar
Banned
Re: Re: Which wire is positive/negative?
no clamps, there's a snap-on plastic thing which clips both wires to the speaker. I cut the wires to that and put clamps on each one. Each door has different colors from eachother and I don't feel like hassling with trial and error.. thought I'd ask here first.
Old 10-16-2003, 08:39 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: Re: Re: Which wire is positive/negative?
one thing you can do is turn up the speakers and if it looks like the cone is moving inward and not being pushed out, it is out of phase
Empty Pockets Racing Member #1
Old 10-16-2003, 09:55 PM
Ricochet's Avatar
Banned
Re: Re: Re: Re: Which wire is positive/negative?
I've never heard of that... damn, thanks man.
Old 10-17-2003, 12:08 AM
60hz163.5db's Avatar
60hz163.5db 60hz163.5db is offline
yes if the speaker is moving inward and producing no bass it's out of phase. The easiest way is to speaker pop em behind the head unit or yes try them one way and switch if needed.
"Working in car audio has it's advantages, but it also shows you how much money ppl have to waste."
Old 10-17-2003, 01:30 AM
k67p67 k67p67 is offline
My database indicates:
LF+ = blue
LF- = gray/black
RF+ = red/green
RF- = brown/black
LR+ = blue/yellow
LR- = gray/white
RR+ = red/yellow
RR- = brown white
You can always hook it up and switch one side to listen for an increase/decrease in bass response.
SoundDomain link (system pics)
~ALL SHOW - NO GO~
Old 10-17-2003, 10:34 AM
Ricochet's Avatar
Banned
That's exactly what I needed. I'll hook it up correctly and also check cone movement. Thanks a lot guys.
