Old 10-16-2003, 11:18 AM
iceblend's Avatar
iceblend iceblend is offline
Question Help on panel lines
Can someone give me a step-by-step guide to doing perfect panel line? i really need HELP..thnks..
Work In Progress
Old 10-16-2003, 05:55 PM
hirofkd's Avatar
hirofkd hirofkd is offline
Re: Help on panel lines
1) Read FAQ
2) Thin a paint, and let it flow along the goove.
3) Buy a Micron Pigma or a very fine drawing pen, and draw the lines along the groove.
Hiroaki Fukuda
Old 10-16-2003, 11:44 PM
Blackout Blackout is offline
get yourself a gundam marker from gundam store and more.com. I think that they cost about $3.00 per marker and they are fantastic. Just get the very fine black marker, and you'll be good to go.
Old 10-17-2003, 12:13 AM
AE86er's Avatar
AE86er AE86er is offline
HOPE THIS HELPS!!!!
http://www.briansmodelcars.com/tutor...ID=7&CurPage=1
http://www.tamiya.com/english/howto/car1/tip3.htm
Old 10-17-2003, 10:33 AM
iceblend's Avatar
I tried the "let it flow along the groove" method...totally destroyed my work..the paint did not flow along the grooves....and i believed it's been thinned enough. and the i cant clean up the blot of paint after doing the groove thing!!!!!=x
Work In Progress
Old 10-17-2003, 11:00 AM
hirofkd's Avatar
That's probably because...
1) goove was not sharp. -> rescribe the panel line with the sharp side of the hobby knife. This gives the line extremely narrow, crisp and sharp.
2) paint wasn't thin enough -> paint and thinner ratio is something like 1 to 10 or even thinner.
3) types of paint for the body and panel line should be different. -> enamel and waterbase paint won't affect the lacquer paint, such as Tamiya TS spray or automotive body paint. It's a common practice to use those for the body, and use enamel for the panel line, so that enamel thinner won't affect the paint used for the body.
Hiroaki Fukuda
Old 10-17-2003, 11:43 AM
iceblend's Avatar
perhaps that explains the problem...thnks for the help bro!
Work In Progress
