Old 10-16-2003, 10:03 AM
Touge180 Touge180 is offline
Fog Lights
I'm lokkin to get a good set of fog lights for the sedan what are some nice one's that don't cost to much and are just right.
My car doesn't look fast and my car doesn't look furious...so when you see my taillights fade into the distance, remember this: I was into cars long before you and the rest of the trend-humping lemmings showed up and I'll be into cars long after you move on to the next pop-culture trend that you decide to shamelessly bastardize
Old 10-16-2003, 10:16 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
i actually just bought a pair of 3A racing ones from pep-boys and installed 100w bulbs instead of the 55w they come with, they work fine and are a CF pattern style.
here is a couple of pics of what they look like, not very good pics either.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 10-16-2003, 10:19 AM
to far away get closer
Old 10-16-2003, 10:46 AM
crxlvr's Avatar
i dont even have a camera, this pics are from like june or something when my sister was here with her camera.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 10-16-2003, 10:53 AM
crxlvr's Avatar
ok here is a pic of what they look like, except mine are CF.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 10-16-2003, 02:59 PM
H4Bangin's Avatar
H4Bangin H4Bangin is offline
Send a message via AIM to H4Bangin
get some PIAAs
Old 10-16-2003, 03:33 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Re: Fog Lights
You guys know of any just plain rectangular ones, sort of the shape of the JDM ones?
Old 10-16-2003, 03:36 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: Re: Fog Lights
you can get ones that look like the jdm ones from wal-mart, they're a little smaller, but most people probably won't be able to tell the difference
Empty Pockets Racing Member #1
Old 10-16-2003, 03:42 PM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
I got some Pilot fog lights for my car and also upgraded to 100w bulbs. - They make a nice black housing clear rectangle style that fits well with our boxy ass styling of car...I bought the yellowish/blue lensed ones, and wish I had stayed clear now, they are yellow at night, and I prefer them to be white :-\
I would recommend the following ideas, especially if going 100w...
Get a real relay box which is powered and has a separate connection for each light (total of 5 prongs, instead of the shittier ones with only 4 that sometimes come with cheaper fog light systems) - (~$5 at Autozone) - This way you aren't tee-ing a single 12v hot wire to your lights.
The 5 pronged ones connect as:
1. battery (12v feed)
2. switch
3. ground
4&5. lights
Also, I would recommend that you upgrade to a 20 amp switch & fuses (Put a fuse in between the battery and the relay box, and also in between the battery and switch.) The 15amp switches which are generally standard with fog light kits tend to melt with 100w bulbs from the extra current they draw (ask me how I know this ) Also, I'd recommend at least 18 gauge wire...I think I used 16 on my setup....
I tend to basically throw away all the junk that comes with the fog lights and beef up the wiring, connectors and switches, etc.., esp. if I use 100w bulbs. Also remember, when installing the bulbs, never touch the glass of the bulb with bare hands...the oil from your skin will make the halogen bulb fail prematurely.
I wired my switch into an ignition fuse in my block so that they go off when I turn off the key..this is great cuz I'd forget them all the time and kill my battery. A lighted switch also helps with this
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 10-16-2003, 03:49 PM
H4Bangin's Avatar
the amperage should not matter on the switch if u are using relays cause its getting its power from another source and not through the switch
Old 10-16-2003, 03:54 PM
sastanley's Avatar
AF Premium User
Good point - I was thinking about that too as I typed it...it is entirely possible I melted a switch before I knew about relays. I've been thru a few cars in my day, and I have installed fog lights on all of them. That might have been before the relay was put in on a previous car
-Shawn
'91 Civic DX sedan
Old 10-16-2003, 04:56 PM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
while we are on the subject, i was wondering if anyone knows where i can get some good fog lights thst would fit perfectly in the 2 holes in my front end
KoRnSaQ
Old 10-16-2003, 05:01 PM
H4Bangin's Avatar
Re: Fog Lights
i have some that where off of a 98 civic(factory) there kinda big, looks like they might fit
Old 10-16-2003, 05:19 PM
91EF3ZC's Avatar
91EF3ZC 91EF3ZC is offline
AF Premium User
Send a message via AIM to 91EF3ZC
I bought a set from CATZ before I got the factory set. I like the CATZ products alot. CATZ also makes HID kits and they also make the HID lights in Nissan's. PIAA is very good as well, and so is IPF. three of the best AUX. lighting companies on the market.
Visit my EF page:http://www.pbase.com/luv2hover/91_civic_&page=all
Old 10-16-2003, 11:06 PM
Hey guys I just remembered I had a set of 89 Prelude foglights upstairs. They are in great condition. I bought a set of 4 from a guy and pieced together the different parts of 4 broken ones to make 2 complete good ones. They have new bulbs and everything. I bought it all for about $80. I will sell them for $60 shipped. I'm broke as hell now and I don't have the money to hook them up. They are supposedly the same sizes as JDM civic fogs, and they are said to fit into the WW kit perfect. So I wil sell them if anyone wants them.
