Old 10-16-2003, 09:34 AM
yelow88crxsi yelow88crxsi is offline
Send a message via AIM to yelow88crxsi Send a message via Yahoo to yelow88crxsi
Angry What the Hell???????
Ok, i changed my brake pads and rotors last night.....and still everytime i stop my brakes sound like there bad....they are squealing and what not...i just dont get it ....so what else could it be other then my front brakes???
~*Taran*~
alright, this is a girl's car....but i dont drive like a girl....i'll out drive you anyday!!!
Yellow88 Honda Crx Si ~~RETIRED~~ RIP CRX 12/03
~Black 89 Crx si~
zc 1.6 sohc
full exhaust
short shifter
momo steerig wheel
15.6@88mph oh baby oh baby
"The non-turbo supra, z23 cavi, p5t (new protoge? turbo) BEATER!!!*
Im looking for a cheap turbo setup....im me: HndaCrxGirl
Old 10-16-2003, 10:02 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
did you put the anti-squek(i cant spell) on the pads before you installed them?
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 10-16-2003, 10:35 AM
yeah we put silicone (sp?) on them and then heated them up before i drove anywhere.
~*Taran*~
~Black 89 Crx si~
zc 1.6 sohc
full exhaust
short shifter
momo steerig wheel
Old 10-16-2003, 11:19 AM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
Re: What the Hell???????
might be ur rear brakes
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 10-16-2003, 11:37 AM
i was thinking rear brakes too...dont i have drum back brakes??? i know for a fact that my e-brake barely works....what u think?
~*Taran*~
~Black 89 Crx si~
zc 1.6 sohc
full exhaust
short shifter
momo steerig wheel
Old 10-16-2003, 11:48 AM
BLU CIVIC's Avatar
調整器
i thought my front brakes were squeeking...changed them....kept squeeking and it turned out to be my rear drums
The name's Adrian
2011 CR-Z - Stock
Old 10-16-2003, 12:14 PM
91civicDXdude's Avatar
dont even worry about changing rear drums.. just buy a rear disc conversion from me
Old 10-16-2003, 12:26 PM
BLU CIVIC's Avatar
調整器
i already brought the drums.....i'm willin g to take them back if u sell me the conversion kit for the same price
The name's Adrian
2011 CR-Z - Stock
Old 10-16-2003, 01:54 PM
how much u want to sell the conversion for??
~*Taran*~
~Black 89 Crx si~
zc 1.6 sohc
full exhaust
short shifter
momo steerig wheel
Old 10-16-2003, 01:58 PM
oh, u should have seen my front brake pads....they were rubbing metal....now there is brake dust everywhere........how do i clean it from under the wheel-well......and heres another question...my valve cover gasket leaks..and there is oil all under my car...(when i was changing brakes...on the lift i had it up too see under my car)...how do i clean all that shit off?
~*Taran*~
~Black 89 Crx si~
zc 1.6 sohc
full exhaust
short shifter
momo steerig wheel
Old 10-16-2003, 02:07 PM
CZ-R's Avatar
CZ-R CZ-R is offline
Send a message via AIM to CZ-R
To clean the brake dust I'd use some Simple Green or Super Clean. Be careful though... Both of those products are known to eat paint. All you do is spray it on there, wait a couple minutes & hose it off. If that stuff doesn't work try some Brake Cleaner. That stuff will clean anything!
Old 10-16-2003, 02:13 PM
4-Door Flunky 4-Door Flunky is offline
AF Premium User
Simple Green rocks! Just don't get it in your eyeball.
When I stomped on my brake pedal hard, I used to get a whoom-whoom-whoom sound. I replaced the pads, the rear shoes, and finally the front discs.
It kept happening. I finally figured out it was a front wheel bearing. Once I replaced that, my car got much quieter and now it brakes quickly and smoothly.
Flunky
Old 10-16-2003, 03:38 PM
ok...umm.....so to clean my wheel-wells i have to use that green stuff...and then hose it off......will water effect anything under my hood...because i dont have a splash guard....so pretty much if i hose it down, all my shit is going to get wet...right??
~*Taran*~
~Black 89 Crx si~
zc 1.6 sohc
full exhaust
short shifter
momo steerig wheel
Old 10-16-2003, 03:56 PM
CZ-R's Avatar
If you have an 'open element' (K&N style/cone) fliter you can just wrap a plastic bag around it to keep it from getting wet. Just to be on the safe side, I'd wrap one around the distributor as well...
Old 10-16-2003, 04:48 PM
BullShifter's Avatar
If your e-brake barely works then that means your rear pads/shoes are shot or its out of adjustment - which should be done about every year. Also when you clean/lube/adjust - that usually makes them last longer.
DO NOT heat up new brake pads(unless performance pads) Drive normal on new pads for atleast the 1,000 miles.
The best way to remove brake dust from non-painted surfaces would be a wonderful invention called BRAKE CLEANER. To clean remove oil, brake cleaner works or degreaser.
Replace your v/c gasket & slash guards(they were there for a reason)
