Old 10-16-2003, 01:48 AM
yeet yeet is offline
New and Need Help removing wheels
I am going to change the wheels on some of my diecast but i dont want to hack them out. what is the best way to remove the wheels.
Old 10-16-2003, 01:06 PM
Gafoto's Avatar
Gafoto Gafoto is offline
Send a message via AIM to Gafoto Send a message via MSN to Gafoto
Re: New and Need Help removing wheels
Give us a builder name (maisto, etc), car model, and scale and we can prbly help you.
Old 10-16-2003, 09:17 PM
1/18 scale hotwheels/burago/maisto if that helps
Old 10-16-2003, 09:35 PM
specmodeler's Avatar
specmodeler specmodeler is offline
The way I do it is by simply cutting the wheel off, you drill a hole were the original wheel was and slide in the axle, or if you cant drill a hole then you need something to hold the axle and you glue it to the chassis and slide the axle through.
Old 10-17-2003, 12:21 PM
Gafoto's Avatar
For maisto you can pop the wheels off by prying them off their wheels assembly. I usually use a screwdriver for that. Make sure to apply even pressure to the wheel or you may snap the assembly.
For bburago its basicly the same thing as maisto though they don't fit together the same way.
For how wheels the front wheels are usually held in by screws so those are easy to remove. The rear wheels can be taken off by grabbing each wheel and twisting in opposite directions as you pull. If they're stuck try using vice grips to get em out. Cutting the axle with a dremel is the last resort since it makes putting the wheels on anything else a real pain in the ass.
Old 04-03-2004, 01:45 AM
corvettes4life corvettes4life is offline
Send a message via AIM to corvettes4life
how do u remove them on a 1:24 Maisto car?
Old 04-03-2004, 10:34 AM
Gafoto's Avatar
For 1:24 Maisto cars you just need to pull the wheels straight off. They should come off easily
Old 04-03-2004, 05:24 PM
PETET's Avatar
PETET PETET is offline
BBURAGO, just pull the wheel outwards. may need some force
Old 09-25-2015, 09:07 PM
stephen nelsen stephen nelsen is offline
i need help on removing wheels off a Maisto 1/24 scale car its kinda hard
im new and need help 5thgencivic '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 11-18-2003 02:30 AM
New and need help :) punken Galant 0 10-11-2003 09:26 PM
Please Help!!! Im New And Need Help On My Car Xplosive17 Integra 1 08-10-2003 04:16 PM
Im new and need help. TURBO_EK4 Car Modeling 0 08-29-2002 09:20 PM
Audiogalaxy users!! New and need help! LX98Civic COMPLETELY off-topic 4 02-08-2002 10:54 PM
