Old 10-16-2003, 01:44 AM
Jay eS Iye's Avatar
Jay eS Iye Jay eS Iye is offline
Send a message via AIM to Jay eS Iye
short shifter vs regular
ok i took out my old shifter from my car last night, and i've set it next to my short shifter that i got off eBay. the actual lengths are the same, the only difference is that the ball on the short one is higher up than on the stock, so the lower section of the shifter is longer. is this how it should be, or do i get a crap shifter? i know short shifters are supposed to shorten the throw, but how exactally?
The Civic is gone...
The Camry never ran...
The Chevy is here to stay...
The Ultimate Honda Engine
Old 10-16-2003, 02:01 AM
BullShifter's Avatar
Re: short shifter vs regular
Thats how a short shifter should be. Since the bottom part is longer, the top moves less. IMO if you got no-name brand from ebay, its crap. How much did you pay? My quality Hurst was only $50
Get yourself some poly shifter bushings - $10 from summit racing
How does it work? Get 2 pens - lay them on something - put one on top of the other at a 90 degree angle. slide it so there is a 1/2" hanging off one side - now push down & watch how much the pen moves, not make the part hanging off longer & bam just like a short throw (well kinda) Its all about pivot points.
Old 10-16-2003, 02:51 AM
91civicDXdude's Avatar
ricer mentality is that "short shifters" are shorter than the stock shifter.
Its all about the length under the pivot point. they are "short throw shifters" not just short shifter. it is true, however, that making the top of the shifter shorter will actually give you a slightly shorter throw, but this is only becuase you are moving closer to the fulcrum. this also has you putting a lot more effort into shifting which over time, leads to transmission failure.
Old 10-16-2003, 09:37 AM
Jay eS Iye's Avatar
aight so short throw shifters are longer under the pivot point? and how extreme could you go with that?
and why would an eBay one be crap? i got it for under 20 shipped
and i plan on going to Autozone to get some poly bushings, hopefully they have them b/c i want to get my car together (shifter and new tranny) this weekend
Old 10-16-2003, 09:52 AM
Jay eS Iye's Avatar
Re: Re: short shifter vs regular
found a picture of B&M's page (www.bmracing.com) that explains well how a short throw shifter works
they also have instructions on how to install one, i don't know why i took off the center console, guess i heard wrong...
Old 10-16-2003, 11:17 AM
technically, you can make it as short as you want. A friend of mine who has a del sol VTEC, he took his stock shifter, removed it from the car, cut it in half under the pivot point, and welded in a socket the same diameter as the shifter. his car shifts amazing. I love it.
It sounds ghetto, but it works and he bangs the shit out of the gears and it hasnt broken yet. with little to no effort, you flick your wrist and its in the next gear. its tight.
Old 10-16-2003, 11:35 AM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
i had an ebay one and never had any problems out of it......but one thing i did have a problem with was the shift linkage.....there was a long round black piece sticking out and it put a hole in my exhaust....
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 10-16-2003, 03:02 PM
Jay eS Iye's Avatar
adrian, was that result of the eBay shifter?
so if i were to take say my short throw i have no, and cut and weld an extension in under the pivot point, would it be even better? i'm just wondering if there is a point where the linkage is too low or something
Old 10-16-2003, 03:56 PM
BLU CIVIC's Avatar
調整器
Re: Re: Re: short shifter vs regular
that part i'm talking about we took a u-saw and cut it off...
The name's Adrian
2011 CR-Z - Stock
Old 10-16-2003, 04:32 PM
Jay eS Iye's Avatar
Re: Re: Re: Re: short shifter vs regular
what piece exactally is this?
Old 10-16-2003, 04:40 PM
BLU CIVIC's Avatar
調整器
Re: Re: Re: Re: Re: short shifter vs regular
i dunno...it was a long circular bar that was attached to the shift linkage near the shifter....
The name's Adrian
2011 CR-Z - Stock
Old 10-16-2003, 04:53 PM
Re: Re: Re: Re: Re: Re: short shifter vs regular
Dont cut/weld your shifter, that a last resort. Buy a quality name brand shifter & no need to worry. Its only a frickin' shifter.
Old 10-16-2003, 05:18 PM
BLU CIVIC's Avatar
調整器
Re: Re: Re: Re: Re: Re: Re: short shifter vs regular
this was some extra piece that was on it....mabey it was just on my 91 std b/c it wasn't on my 90 std
The name's Adrian
2011 CR-Z - Stock
Old 10-16-2003, 06:42 PM
XxLuckyLisaxX's Avatar
XxLuckyLisaxX XxLuckyLisaxX is offline
Send a message via AIM to XxLuckyLisaxX
what do the poly shifter bushings do for you???????????
Keep it real, and share the knowledge.....
Say NO to Primer!!
Old 10-17-2003, 12:09 AM
Stiffen the stabilizer making the shifter feel tighter & more responsive.
where can i find a short shifter with bronze shifter brushings to make for nice, tigh limer MX-3 1 03-31-2005 04:35 PM
Is there any downside to getting the UUC Short Shifter? Seriously! (more) Dean323i 3 Series 1 10-12-2001 04:27 PM
Yes just bought me a pacesetter short shifter...now I have to install it! zykotik General 7 09-06-2001 01:00 AM
Stillen Short Shifter jmgladden General 3 08-23-2001 01:50 PM
short shifters... jcl603 General 10 07-11-2001 01:49 AM
