Old 10-15-2003, 08:35 PM
Masta's Avatar
Masta Masta is offline
Send a message via ICQ to Masta Send a message via AIM to Masta
Battery Draining
what could cause a battery to drain while the car is off with nothing on. Like.....the car jump starts fine, and the battery goes to 12-14 volts, then when u turn it off, the battery starts draining till it reaches 5 volts. I've tried others forums about this problem, and i'm just trying to see what everyone has to say. Someone told me that if my intake is touching the battery, it could be draining it.
Old 10-15-2003, 08:53 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Sounds like you have something called parasitic load. It's when something in your car isn't turning off when it should, such as a little light bulb or something like that. It slowly drains your battery.
To test this however you need a Multimeter. Put the leads on the battery. It should show how many volts the battery is at. Than what you do is pull fuses until you notice the voltage go up to normal. Than you know the parasitic load is on that circuit. Bust out the wiring diagram and look for lights and stuff on that circuit that could be on all the time from accidentally grounding or something like that.
I can get you specifics on how to do this if you feel inclined to. If I were you until then disconnect the battery at night or something so it doesn't not start in the morning.
slammedcivicsi's Avatar
slammedcivicsi slammedcivicsi is offline
It could be numerous things....if the intake was touching the battery you would see arching.....so if your intake has a hole in it...and is all scarred up...then that could be it....but if it only goes down to 5 volts....I say take it out of the car and get it charged.....because it might not have a good charge, it might have only a surface charge.....so thats why it loses its voltage.....how old is the battery......you could also have an electrical gremlin in your car somewhere. Ive seen drains in electrical systems many times. Get that cheked out...any battery shop can do this by putting their AVR Machine on and checking the amperage current running through the system. A local shop can do this....usually for free.....if they want to charge you a bunch go to your local pep boys or something and you can get a thing similar to a voltmeter that will clamp around the positive cable on your battery and will connect to your negative terminal and do the same....it will show the amps running through the system....if the car is off....it should be zero.
Hope this helps !
-Brad
89 DX: LS Powered
88 CX: Project ZC
Old 10-15-2003, 08:56 PM
Masta's Avatar
thanks guys for responding quickly. It is a new battery, i changed the battery like 4 times, and it has done the same thing. and FourthGenHatch, can u get me the specifics?
Old 10-15-2003, 09:07 PM
Re: Battery Draining
Ok. I have a book from school that tells you about it. I will scan in the page. Check back in like 10 minutes.
Old 10-15-2003, 09:13 PM
Re: Re: Battery Draining
Hook up the Multimeter for Amp testing like this thing says. Than pull the fuses until it goes to an acceptible number to figure out what is draining the battery.
Old 10-15-2003, 09:26 PM
Masta's Avatar
thanks again man, i noticed that it said something about the alternator belt.....when i start my car up, my alternator belt squeeks like hell, and it looks worn out, you think that would also cause a problem?
Old 10-15-2003, 09:31 PM
It could be a problem for the fact that perhaps your battery is not getting charged up by the alternator. It wouldn't hurt to get a new belt I guess.
Old 10-15-2003, 10:31 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
i've seen this alot at work, if its a maintenance battery, then i bet you havent been popping the caps off your battery and filling the cells up if they drop, if your plates are uncovered and corrode then ur battery wont last too long, also, get a hydrometer and check ur acid in the battery, if the thing inside the hydrometer floats fairly high, then ur acid is fine, if it doesnt float, then that cell is dead/weak,
just something else to try
Old 10-15-2003, 10:34 PM
1PhatCX's Avatar
if ur alt belt squeeks, try adjusting ur alternator to put a bit more tension on ur belt to make it tight and not loose, i noticed when i put my optima yellow top in my car, my belt sqeeled like a mofo, and it didnt do it that much before when i had a normal battery in my car, tightened the belt and no more squeel
Old 10-15-2003, 10:48 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
do like 4thgenhatch said, but do it with a test light because its easier to watch as you pull fuses.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 10-16-2003, 11:15 PM
Re: Re: Re: Battery Draining
Never use a test light. In a parallel circuit adding another wire to the circuit (using a test light) lowers the resistance. Ohms law tells us that voltage divided by resistance = current (amps). So by lowering the resistance you increase the amps and you can fry your circuit that way.
Old 10-16-2003, 11:41 PM
EF You's Avatar
EF Life Giver
Re: Re: Re: Re: Battery Draining
not gonna fry the circuit if the only thing between the ground strap and the ground terminal on the battery is the test light. thats the easiest way to test it. then its not parallel, its series.
2001 gls battery drain jetta_help_needed Jetta/Vento/Bora 7 02-18-2011 01:37 AM
2006 Grand Prix Battery Drain wratchetjaw Grand Prix 9 12-20-2010 05:18 PM
Battery draining rocketwild Lumina 2 06-30-2009 04:47 PM
2001 Olds Alero Battery Drain Issue Xenokira Alero 3 04-20-2009 11:04 PM
2001 Cavalier Battery Drain Problem - HELP amberdamber7 Cavalier Problem Diagnosis 25 03-25-2009 07:30 PM
