Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 10-15-2003, 06:48 PM
o0Quicksilver0o's Avatar
o0Quicksilver0o o0Quicksilver0o is offline
Send a message via AIM to o0Quicksilver0o Send a message via MSN to o0Quicksilver0o
Question Engine Stress
Hey, I am getting a turbo put onto a LS b18b1 and i was going to rebuild the motor. I am eventually going to replace all the internals, but I am just curious which of the internal parts of an engine take the most beating while driving and while running under high boost. Thx alot!
Old 10-15-2003, 07:19 PM
maxspeedhonda's Avatar
maxspeedhonda maxspeedhonda is offline
Send a message via AIM to maxspeedhonda Send a message via Yahoo to maxspeedhonda
Your pistons, rods, head studs, and clyinder walls/sleeves. The first thing to go will prob be the clutch though.
Old 10-15-2003, 07:58 PM
Aight thx man. Out of those what would you say took the most beating under a high boost enviroment? And how about the crank shaft... does that take a beating at all with higher boost?
Old 10-15-2003, 09:39 PM
93weed_eater's Avatar
93weed_eater 93weed_eater is offline
Send a message via AIM to 93weed_eater
under any kind of forced induction with heavy driveing you're going to strain the whole engine. the weak points are place where metal to metal contact is made. like pistons and cylinder walls. Any time something rubs against something it causes wear. most engines are able to handle so much in stock form. you could go ahead and do the turbo with correct engine management and be alright on stock internals for a good bit depending on your setup and amount of boost. you clutch is something that is a must to replace too. they can go in a matter of weeks when driving hard with a turbo car that wasn't ment to have a turbo from the factory.
Old 10-15-2003, 10:36 PM
boosted331 boosted331 is offline
pistons pistons pistons pistons
Usually the first thing to go, if you dont run a good EMS I forsee cracked ring lands and possibly broken skirts.
Replacing my '98 regal engine. Is this a good rate and engine price? bchalker Regal 1 08-25-2009 07:05 PM
97 lumina engine acting erratically. aptivaa12 Lumina 5 04-22-2009 09:42 PM
For Sale Looking for engines or trannys?? StephanieO Parts for Sale 0 04-17-2009 09:24 AM
Will an engine from a 99 LX fit a 96? in_the_peg Crown Victoria 1 03-14-2009 09:06 AM
