Old 12-07-2001, 03:15 AM
awaken1973 awaken1973 is offline
Send a message via ICQ to awaken1973
Painting spoilers
another complex parts which consist of 2 or more details
I have no idea which do first:
If I glue it together and sand it well it looks better (no joint lines)
but how to paint inside the spoiler then?
If they painted separately and then glued together the joint remains
Old 12-07-2001, 03:40 AM
Guiddy's Avatar
Guiddy Guiddy is offline
Usually sprayed in separate pieces, and then I fill the gap with krystal Klear, and hen wipe away the excess with a wet cloth. It fills the seam lovely and makes it look smooth!
Old 12-07-2001, 04:42 AM
How do you make joint invisible? As i understood Krystal clear is just kind of transparent glue, isn't it?
Old 12-07-2001, 05:05 AM
pkw1's Avatar
pkw1 pkw1 is offline
I use a paste form putty to fill the gaps, then sand prime, then paint, but painting is much more difficult when the spoiler is added on already sometimes,
what I also tried is put the spoiler on without glue to see how much gap there is, then cover trunk of the model where the spoiler to be mounted with some scotch tape, or something that has a smooth non-stick surface.. then apply some paste form putty on the spoiler's mounting spots.. push the spoiler down on the spot where it mounts.. the putty will get squished into the gap's thickness, then when it drys, you can sand off the stuff that was squished out.. leaving a filler for the gap..
dont' know if you guys understand what i said, but that's what i do for some spoilers
All projects stalled...
Need to settle in on my new job, and don't have time to built models just yet.
Old 12-07-2001, 01:28 PM
Guiddy's Avatar
Dunno! Just worked really well on my R33 Skyline!
I guess because it is lacquered, and the glue sets clear, looking like a continuation of the lacquer!
ViS Spoilers chevcav01 Non-Performance 0 04-05-2010 09:12 PM
Trying to find the piece that goes under spoiler but above the tail lights DizzyTwinTurbo 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 1 01-22-2010 12:18 AM
How do you remove the spoiler from the hatch? Sonic Eclipse Exterior and Wheels 3 10-08-2009 11:35 PM
1970 Chevelle Paint job xraab Classic Cars 1 05-24-2009 09:53 PM
New Paint Color "HELP" panteli2011 Thunderbird 3 05-01-2009 02:40 PM
