Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 10-14-2003, 09:27 PM
maurs maurs is offline
greddy turbo
I'm planning to get a greddy turbo kit for my 98 gsr. i would like to know what i need to do to boost 12psi safely. I want do run about 6-8 daily. I was wondering if i could change the internal waste gate to an external, how would i do so? help me
Old 10-15-2003, 12:15 PM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
Re: greddy turbo
a stock honda motor can only take 10psi at max on the stick internals.. you need new upgraded fuel sys. and also need to reinforce the internals to run safley,also some upgraded ignition sys..
1
Shift_BOOST
97 s14
Old 10-15-2003, 09:42 PM
93weed_eater's Avatar
93weed_eater 93weed_eater is offline
Send a message via AIM to 93weed_eater
An LS can handle up to 12psi on a "properly tuned" turbo set up. the problem with most of the VTEC engines is the higher compression. I've also heard you shouldn't even run 10psi on a GSR unless you're going to rebuild the internals.
Old 10-17-2003, 11:20 AM
Re: greddy turbo
what internals would i need to rebuild if going to run 12psi of boost?
Old 10-17-2003, 03:20 PM
turbo2nr's Avatar
Re: Re: greddy turbo
pistons rods and new head gasket lowere compression to 8.5:1 or so also if u wnat new heasd studs now is the time and re sleving the block isnt a bad idea ither..
1
Shift_BOOST
97 s14
Old 10-17-2003, 04:02 PM
Re: Re: Re: greddy turbo
What about the wastegate? Could I change the internal for external?
Old 10-17-2003, 10:43 PM
turbo2nr's Avatar
Re: Re: Re: Re: greddy turbo
at such low psi the internal is ok..
1
Shift_BOOST
97 s14
Old 10-17-2003, 11:58 PM
MXrider22 MXrider22 is offline
internall is ok... but external is nice if you want to turn up the boost with a boost controller for that 1 run downt he track... Question for turbo2nr... if you did pistons and rods... why would head gasket matter... i meen, just get the right compression pistons instead of lowering compression with the gasket right? im still a noob... but im trying to learn all i can i wouldt think if you were alreayd doing pistons and rods that you would need a thick gasket
Old 10-18-2003, 09:46 AM
if you get the right pistons you don't need a thick headgasket to lower compression but you should get a good one.
Old 10-18-2003, 10:19 AM
thanx for the answer... i thought so
Old 10-18-2003, 11:48 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Getting the thicker head gasket to lower the CR is a bandaid fix and is a bad way to acomplish the goal. However you do need a good head gasket to hold up to the increased cylinder pressures. And I think if you are going to buy a kit (which I suggest building a custom kit) then the Greddy is not so great. I would go with revhard or drag, they make nice kits best off the shelf kits IMO.
Old 10-19-2003, 12:12 AM
turbo2nr's Avatar
Re: greddy turbo
thats what i ment is that if you reinforce the internals you might as well change to a thicker head gasket to hold up to the added boost pressures..
1
Shift_BOOST
97 s14
Old 10-19-2003, 12:21 AM
Cool
hmm... rev hard... i think maxrev makes a kit for ya... i dunno about dra though iv heard there manifolds suck n dont flow right... but that just what I've HEARD... not from experiece so let these guys with experience let ya know... just giving you my opinion from reading around
Old 10-19-2003, 12:37 AM
Re: greddy turbo
I have to go with the greddy turbo kit because it's the only kit street legal. I'm not trying to build some crazy turbo race car. I simply just want to drive it daily and mess around with peeps on the streets. I'm planning on getting:
Greddy turbo kit
Greddy intercooler type 31v
Greddy profec b spec
Greddy type s b.o.v.
Greddy turbo timer
I was wondering if I needed anything else to run about 6-8psi, like ignition system or fuel?
Also I would like to change the internal wastegate for an external, I don't want to deal with boost creep. How could I change the wastegate to external
Old 10-20-2003, 06:21 PM
Greddy turbo kit
Greddy turbo timer
can anyone help me?
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
