Go Back   Automotive Forums Car Chat > Oldsmobile > General Discussion
Old 10-14-2003, 07:18 PM
destroyer destroyer is offline
307-350 swap
Hey guys I have a couple of questions regarding using a 350/403 Olds in place of my 307 in my 87 Caddy. Would the 350 motor bolt right in and would I be able to use all the accessories/brackets off the 307? Also would the intake/carb/distributor/harmonic balancer off the 307 work? What mods would I have to make? Thanks in advance.
Old 12-01-2003, 09:46 PM
kpw olds kpw olds is offline
Re: 307-350 swap
Yes, Yes, Yes...
All Olds small blocks will interchange. However, does the Caddy have fuel injection? If so, then the computer MAY have to be re-programmed for added fuel delivery (if Open Loop).
You would need the balancer for the engine you choose to use--as they are different...
Further, tranny may have to modded to handle greater torque.
See the engine FAQ at 442.com. I'm swapping a 403 in place of the 307...
350 motor swap bowtieballs2000 Performance 0 03-09-2009 11:26 PM
305 to 350 swap? Cop_Dodger Camaro Discussions 1 12-14-2005 03:08 AM
Need help with 307 - 350 conversion legion009 Nova 1 06-22-2005 08:17 PM
307 engine swap in my 83 Hurst scottjohnson57 Cutlass Series 6 01-20-2005 10:59 PM
I need 350 swap help ! blackbob Camaro Discussions 3 09-04-2002 08:08 PM
