Old 10-14-2003, 04:46 PM
specmodeler's Avatar
specmodeler specmodeler is offline
air intakes
anyone know how to make air intakes
Old 10-14-2003, 04:57 PM
hirofkd's Avatar
hirofkd hirofkd is offline
Re: air intakes
Do you mean NACA type inlet opening or chimeny like one that sticks out?
Either way, you can make it with a sheet of styrene.
Hiroaki Fukuda
Old 10-14-2003, 05:31 PM
weaponCIVIC's Avatar
weaponCIVIC weaponCIVIC is offline
i cut a part of the chrome parts holder out, heat it up and bend it. your on your own with the filter
Old 10-14-2003, 10:42 PM
MR-2RaCeR's Avatar
MR-2RaCeR MR-2RaCeR is offline
Send a message via AIM to MR-2RaCeR
For the air filter, u could use a spray can nozzle, and then use styrene pipes or the parts tree for the rest.
-Henry-
Old 10-14-2003, 10:56 PM
Re: air intakes
That would be quite big, no?
AF MODELING FAQ
"Oh what a feeling.- Toyota
Old 10-14-2003, 11:04 PM
MR-2RaCeR's Avatar
Re: Re: air intakes
Well yeah, but you could cut off some of it.
-Henry-
Old 10-15-2003, 08:13 AM
EMAXX's Avatar
EMAXX EMAXX is offline
Send a message via AIM to EMAXX Send a message via MSN to EMAXX
Re: Re: Re: air intakes
I like that idea above about using the chrome tree to make it. I might have to try that sometime. I've already made an exhaust, and a light bar out of the tree. lol
Old 10-15-2003, 03:51 PM
Re: air intakes
I tried the spray can nozzle but it is just to big and doesn't look realistic, maybe the toothpaste cap will work?
Old 10-15-2003, 07:52 PM
MR-2RaCeR's Avatar
Re: Re: air intakes
Maybe, all you really need is something with grooves going up and down.
-Henry-
Old 10-15-2003, 08:45 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
Take a peice of styrene rod (or tube) the diameter you want your filter to be. 3/16 should be about right, I'd guess without a ruler in my hand. Take a saw, a razor saw, but one with teeth about 1/16 or so OC, and press it against the styrene tube/rod as if you were going to cut it. Then run the blade down the length of the tube/rod, so that the teeth in the blade scribe parallel grooves the length of the tube. Do this a few times around the tube until it has grooves all the way around. It make take a few tries to get it to go straight. Ideally, you can do a considerable length of tube like that, and cut off a bit for each intake you make. Then cut a round peice of styrene (if you can find a hole punch the correct diameter, that will make it much easier) to glue to either end of the filter, to simulate the plastic cap on either end. Then use styrene rod (1/8 inch or so, guessing again) or sprue or whatever as the intake tubing. You can bend the tube over a candle or by heating it in boiling water (be careful, I have plenty of burns from bending styrene).
This way you can make the filter whatever size you want, and won't be limited to using the enormous spray nozzle or even bigger toothpaste cap. It's easy too, and you can make several dozen all at once, throw them in your parts box and grab them as you need them. Thats probably the most economical, time and money wise, way to do it, too. Anyway, have fun!
Old 11-03-2003, 03:50 PM
Jurva's Avatar
Jurva Jurva is offline
Do you guys have pictures of your scratch build airfilters?
240sx s14 CARB Legal Cold Air Intake? Dope Minded Technical 3 01-26-2011 03:48 PM
'00 cavalier, odd noise and oil in air intake/throttle body warik Cavalier Problem Diagnosis 4 04-23-2009 06:11 PM
backfirea and caught air filter on fire!!!! davidrobert2 LeSabre 8 03-27-2009 07:22 AM
cold air intake vs short ram air intake??? sgt d Non Specific 5 06-17-2005 10:34 AM
Cold air intakes and short air intakes Boarder03 Eclipse 2000+ 3 03-29-2005 03:43 PM
