Old 10-13-2003, 06:27 PM
richkatw richkatw is offline
Starting
I Have a 97 Grand Voyager, with 3.0 liter in the morning when I go to start the car it starts right up and drives just fine however after driving for awhile and I shut it of let it set, I go to start it and it cranks fine but it does so for about 3-5 sec. before it starts to kick over and when it kicks over it sputters a little, once it is running it drives fine. one thing it does do is when you are on the interstate and you are in limbo (not speeding up and not slowing down) it does a little jurk every once in awhile. thanks
Old 10-23-2003, 01:39 AM
Winddrifter Winddrifter is offline
Re: Starting
That exact same thing happened to me too. It was the fuel pump which is located in the tank. You have to lower the front of the tank to get at the pump. It is a fairly easy job. Just use up as much gas as you can before you start. Or, on top of the tank is a capped line that is for siphoning the tank empty.
Good luck,
Jim
Old 12-14-2003, 04:25 PM
campmaley campmaley is offline
I had this happen to me along with many other things. I changed my fuel filter twice. The second time I put extensions on the lines and moved the filter. If it happens again i don't have to take the gas tank down again.
Old 01-01-2004, 06:23 PM
sonnytris sonnytris is offline
Re: Starting
Mine will not start but almost did once and acted like no fuel...I have never changed or knew about the rear filter your talking about..This could be my problem
thanks
Hard Starting 97 Riveria lavendorj Riviera 3 03-14-2009 08:52 PM
No start, start, no start, start+smoke CLR01 Blazer 14 02-26-2006 01:22 PM
Starts....doesn't start...starts kennycu Park Avenue 3 08-11-2005 10:05 AM
89 Bonneville - Starts, Doesn't Start, Starts, Doesn't Start joshshrag Bonneville 2 04-24-2005 01:24 PM
1989 Bonneville - Starts, Doesn't Start, Starts, Doesn't Start joshshrag General Discussion 0 04-19-2005 06:33 PM
