Old 10-13-2003, 04:29 PM
Qball Qball is offline
Send a message via ICQ to Qball Send a message via AIM to Qball Send a message via MSN to Qball
Unhappy DHP PRD Need answer!
I have a 98 GP GT and i want to get this for it.
now all of the things it says i have to get below do i need to buy anything else besides just the DHP PRD? or does the mechanic go ahead and take care of the rest?
cause it says i need to change this and that and all that crap and i just wanted to get a better understanding.
and does this give me more top end? instead of the damn thing cutting off at 110!
Availability:
In Stock Installation Difficulty:
Installation Instructions:
Read Here
Available for 1997-2002 Pontiac Grand Prix SE (3.8L only), GT and GTP, and developed with the average 3800 enthusiast in mind, this PCM has been designed and dynamometer tested and proven for the following modifications:
3.4" - 3.25" pulley (Grand Prix GTP only)
Cold air induction system (any brand)
Cat-back exhaust system (any brand)
Premium fuel (91 octane or higher is required)
If you have more aggressive modifications (such as a camshaft) done to your vehicle, please consult with us prior to purchasing this product
NOTE: This calibration is NOT intended for stock Grand Prix GTP, but will work well with stock Grand Prix GTs. Additionally, premium fuel IS required.
FEATURES:
Feature list applies to Grand Prix SE (3.8L engine only), GT at all times, and to Grand Prix GTP when performance shift mode is selected
Speed limiter removed
3-1 and 4-2 skip shifts
Transmission line pressure increased
Shift points moved (5800-6000rpms)
Fan turn on points altered as follows:
186 degree F turn on
2 minute fan on at key-off (this feature activates when engine coolant is 179 degrees or greater)
MAF calibration adjusted for proper year
Fuel/spark adjustments as follows:
Enrichens fuel delivery for critical problem areas
Provides a consistent power gain across the entire power band
Reduces spark retard (knock retard)
Removes "40MPH WOT lag"
Dynamometer testing has shown up to 20 HP gain in 60 degree temperatures on a development Grand Prix GTP and 8-12 HP gain in 60 degree temperatures on a development Grand Prix GT using 93 octane fuel. Click here to view the GTP dyno results and detailed explanation. No dyno graph is available for the Grand Prix SE 3.8L or GT as of yet.
Old 10-13-2003, 04:56 PM
The Burning Rom The Burning Rom is offline
Send a message via AIM to The Burning Rom Send a message via MSN to The Burning Rom Send a message via Yahoo to The Burning Rom
Re: DHP PRD Need answer!
Alright..first of all, you don't need ANY other mods to install a DHP PCM. BUT, you will not be getting your money's worth if you don't have at least some exhaust and intake improvements. You will also have to run PREMIUM gasoline for the car to perform right.
As far as a mechanic installing a DHP..I've never heard of it done. Nobody has ever needed a mechanic to do it for them.
BUT, if you do take it to a dealership to have it fixed after the DHP is put in, they will most likely flash your PCM again. If that happens, you WILL have to pay DHP to redo your PCM if you want the improvements again. Neither the dealership nor DHP will take responsibility if that happens.
This will also not GIVE you more top-end. It will remove the limiter, but there isn't much more Top-end there for you anyway past 110.
www.wicgp.com <- Wisconsin Grand Prix Club
1999 Black Grand Prix GT Coupe
1990 Red ASC/Mclaren Grand Prix Turbo Coupe
1990 Metallic Blue & Silver Grand Prix LE Coupe
1979 Blue Dodge Ramcharger
Old 10-13-2003, 09:00 PM
ok well yeah im getting finishing my exhaust out like this coming week, a whole new exhaust.
i just was asking about the installation, is it hard? havent really checked much into it.
umm what does it really do? just makes your car run better, and have alittle more horsepower blahblahblah
someone just told me to look into it because it would help a lot more.
Old 10-13-2003, 09:07 PM
ok yeah dont i feel like an idiot, ahha i just read the directions its not too bad.
also the features i was thinking that i needed to change them somehow haha.
yeah this is a new toy for me so im still learning about my car and all that good stuff.
do you know of me needed the core charge? i know i have to get it but can i refund it?
and is there anywhere else cheaper then PFYC? then 295 plus the 150 core charge?
oh another thing, since i have cold weather where i live (in the winter time or coarse) does it matter weather i get a cold air intake or just a fenderwall intake?
thanks
Old 10-13-2003, 11:05 PM
Ripn12s's Avatar
Ripn12s Ripn12s is offline
Send a message via AIM to Ripn12s
Go to www.clubgp.com and search the classified's. You should be able to get a stock PCM same year as your car for $60-70. Then just send that one to DHP or CYA and have them program that one. That way you save the cost of core charge and if you ever have to have work done on the car you can put the stock pcm back in. I bought a Stock PCM for my 98 GTP for $60 and had Mike D at Cya flash that. So now I can choose to run the DHP or the CYA Racing
The PCM's could possible give you more pull on the top end, especially if your car runs lean. Plug that DHP in and it wont run lean hopefully killing some KR and uping your timing thus uping your horsepower.
I'm helping a local texas guy try to eliminate 8 deg of KR he's seeing with only a 3.4 pulley. His o2's are around .82 which is way lean(atleast I think so), and probably the cause of his massive KR
Install takes maybe 10min, and that's just cause you have to remove the airbox to get to the pcm.
Try to do as much of your own work on the car as possible, and hook up with your local club and go to some mod days. That is a great way to learn about these cars.
Later,
Tim
Old 10-14-2003, 12:56 PM
For that..just do what ripin12s suggested.
thanks
Cold weather doesn't matter, although if you get a lot of snow in your area during the winter, I'd suggest running a pre-charger on the cone filter if you go with a FWI.
One of the guys that was at our mod day back in May pulled off his cone after running it for a year (through the winter), and it was black. He'll be running a pre-charger this winter.
Old 10-14-2003, 03:43 PM
where do i send it off to get reprogrammed?
you said DHP or CYA?????
and i dont think there are any local clubs around here for me.
i live in a town of rice burners and everyone else having a mustang.
anyone here who has a gp are like old people and crap that do NOTHING to there car. bunch of bums, haha.
and which is better, a CAI or a FWI??
Old 10-14-2003, 04:12 PM
'00' GTP '00' GTP is offline
IMHO
I think that FWI is better, but realy they are the same.... only FWI is TRUE Cold Air Intake think about how hot it gets under the hood..... that is realy not CAI that is just better flow, but it is still sucking in hot air. I live in Indiana, and I have had no trouble with the FWI, reguarding the snow or anything.....
2000 Black 4 Door GTP
3.4" pully
FWI
14.5 stock
2003 Red Accord Coupe
V6 6-speed
car-stats.com saies it runs 14.7
Old 10-14-2003, 04:22 PM
I'd go with DHP.
http://www.digitalhorsepowerinc.com
In the debate of FWI vs. CAI, I'm always for the FWI..as it draws air from an area further away from the hot engine bay.
As far as a local club, I'm sure there is a ClubGP chapter in your state. Check out the club chaper listing at http://www.clubgp.com/clubgp/
Old 10-14-2003, 08:32 PM
alright thanks!
Need Answers! slammed89civic '88 - '91 Civic | CRX | Wagon | Shuttlee 5 08-23-2002 11:29 AM
Help! I have a question I really need answered. smittyas00 General Discussion 2 06-11-2002 05:55 PM
Buying car, need answers!! nuckdiver Street Racing 12 03-01-2002 10:25 AM
Hondata gurus...I need answer pls bcause Forced Induction 2 02-11-2002 12:41 AM
question on engine block...need answer soon... 1992G20 General 5 01-02-2002 11:29 PM
