Old 10-13-2003, 03:35 PM
gsf1200m gsf1200m is offline
Need help with headlight
Ok, so my low beam stopped working so I thought the bulb had just crapped out on me so I went and bought a new one.
I put that in and nothing happened.
To make this short, I tested everything and I am 100% postitve that the problem is the power wire going to that bulb, which is red with a white stripe and blue dots.
On the bulb side the wire looked fine, and the plug is also not the problem.
I traced the wire back and I think it might plug in by the passengers feet with two other wires, and that looked good too.
So now I have no idea what to do and need some help...
Old 10-13-2003, 03:50 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Re: Need help with headlight
low beam headlight fuse would be the first thing to check. if you are getting power through that fuse, then its the wire somewhere between the plug and the fuse. i would go there first, and then see whats up.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 10-13-2003, 07:52 PM
I actually forgot to check the fused which should have been the first thing I checked.
Are both low beams on the same fuse or are they on seperate ones?
One low beam works...
2002 Ford Focus - Need help with headlight bulb-replacement. BladeJrs Focus | C Max 1 09-21-2004 08:36 PM
Need help with headlights rocpit 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 2 04-29-2004 10:44 PM
need help with headlights.. stern_fan Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 5 07-14-2002 12:08 PM
need help with headlight 97wvmax Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 5 03-23-2002 03:05 PM
Need Help with Headlights MaxWolf Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 11-29-2001 02:09 AM
