Old 10-13-2003, 12:51 PM
ilikerice883 ilikerice883 is offline
crx head
i have a 91 crx hf and was wondering about putting on a dx head. i think this would give it 30 more horsepower from the spec sheets i saw on the internet. i was also wondering what other head if any, would fit on my hf engine. and also, if the head would work, would i have to replace the timing belt or anything else on my engine to accomodate the new head.
Old 10-13-2003, 12:58 PM
91civicDXdude's Avatar
Its debateable whether a 16valve head will fit on the HF block, due to the fact that it doesnt have the extra 2 valve reliefs.
It would be nice if someone with an HF block would bolt on a 16 valve head and turn it over to check and see if the valves hit.. the HF has dometop pistons and if you could get a 16 valve head on it, it would have some mega compression.
btw, you dont necessarly *have* to change the timing belt, but it is recommended.
86 crx head light switch dljonessr '71-'87 Civic | CRX 1 05-27-2005 07:50 AM
Whats the dif in 88-89 and 90-91 crx head light's cwlewallen '88 - '91 Civic | CRX | Wagon | Shuttlee 3 03-05-2005 03:38 AM
Help!!! CRX Head swap didn't go right!! mattilude '88 - '91 Civic | CRX | Wagon | Shuttlee 10 11-07-2004 10:02 PM
91 crx head bolt onto a 92 civic cx motor? nosfed360 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 04-21-2004 11:34 PM
