Go Back   Automotive Forums Car Chat > Ford > Sierra
Old 10-13-2003, 03:30 AM
ed_crouch ed_crouch is offline
Pinto vs CVH for kitcar
Morning all,
I am trading off between the CVH 1600, and the Pinto 2.0 for a kitcar project (MK Indy).
What are the weights of each engine, fully dressed?? The engine will run twin dellortos or weber DCOE 45(?)s
Also, i want to be able to fit the engine to a Type 9 'box. I know the Pinto mates up to this box, but does the CVH 1600??
Is there any way of modifying the type 9 box to move the gear lever further back? i.e. further along the prop shaft, as without one of those naff, wobbly gear linkage extenders everyone uses, the gear lever either has to have a tractor style dogleg in it, or it is stuffed up under the scuttle.
As a last question, can the DCOEs / dellorto equivalents be modified to run a turbo. I beleive the float chambers have to see turbo pressure, and hence it might just be a case of hooking a couple of pressure hoses up the the float chambers??
Thanks in advance.
Ed Crouch.
Old 12-24-2003, 09:32 AM
tarantula tarantula is offline
Re: Pinto vs CVH for kitcar
CVH is a rare engine with rare accessories...
Old 04-21-2006, 05:54 AM
liquidlunch1812's Avatar
liquidlunch1812 liquidlunch1812 is offline
Send a message via Yahoo to liquidlunch1812
PINTO its easier for add on's
