Old 12-06-2001, 08:38 PM
94'Accord EX VT 94'Accord EX VT is offline
HOw to adjust what your car idles at?
I have a 94 Accord Ex and have the I/H/E setup, and my car seems to be idling really rough because the rpms go down so low. Where can I adjust what rpm my car idles at?
Old 12-06-2001, 08:55 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
1. Either unplug the ECU or the fuse for the ECU for five minutes, then replace it and crank the engine without hitting the gas pedal, keep it running for at least 5-7min, then turn it back off. this should reset your onboard computer so the i/h/e setup doesnt affect the rpm your car is running at, and everything should return to normal.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 12-06-2001, 08:57 PM
is there a way you can manually adjust it?
Old 12-07-2001, 12:07 PM
lx2luv lx2luv is offline
yes its the cable on the throttle body. you can either tighten the bolt on it or loosen it to adjust the idle.
Old 12-07-2001, 01:04 PM
90civichbsi 90civichbsi is offline
Send a message via AIM to 90civichbsi
there is normally a screw to adjust it in your throttle body. If you have a haynes manual it will tell you how to do it. its not hard, i had to do it on mine after i got a new cam. it took me less than 5 minutes.
My 1990 Honda Civic Si
i/h/e
gude head
gude cam
gude ecu
2" lowering springs, camber kit etc.
wings west front bumper
powder coated GSR rims
Old 08-23-2004, 07:43 PM
b18c1integra b18c1integra is offline
Re: HOw to adjust what your car idles at?
Could you send me a pic of those gsr wheels danielgraves3612comcast.net
Thanks.
Old 08-23-2004, 10:24 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
lol wow
DSM geek
Old 08-24-2004, 05:00 AM
almxdupintegra almxdupintegra is offline
I believe the idle screw should be on the throttle body. I just lowered mine by screwing it clockwise.
FRIENDS DON'T LET FRIENDS DRIVE STOCK
Old 08-26-2004, 12:36 AM
hundahunta hundahunta is offline
the right way is to start the vehicle and raise the rpm to about 1,000 rpm, disconnect the IAC valve and lower the throttle to the vehicle idles on it's own and adjust the screw...should be around 450-500rpm. I think then reconnect your IAC valve the rpm will stabilized to about 650-700.. The manual has easy and simple details. I would also check your ignition timing
What Your Car Color Reveals About Your Psyche ned032002 Off-Topic 4 05-19-2008 08:06 PM
what does your riviera idle at in park? Homerjay123 Riviera 7 07-12-2007 01:46 AM
What does your 4g Idle at? quiXilver '88 - '91 Civic | CRX | Wagon | Shuttlee 15 10-12-2004 06:03 PM
how to do it youre self!!!how to paint your car youre self?!!!! driajov Exterior | bodykits | Lighting 1 12-02-2002 07:46 PM
