Go Back   Automotive Forums Car Chat > Toyota > General Discussion
Old 10-12-2003, 04:22 PM
connedale connedale is offline
Toyota Technician Tool List
I am a mechanical engineer (automotive diagnostic equipment) who is tired of with project schedules, long hours, and a dry office work environment. My plan is to become an automotive technician. I plan on working out a good deal with a local dealer ship to work on Saturdays to do simple services and then move to full time later when I feel comfortable. I have some experience in a tool and die shop as an entry level machinist. Other than that, my only wrench-turning experience is at my current employer, which is limited since I spend most my day doing engineering. I have began collecting professional tools. I would appreciate it if an import dealer mechanic would review my list and tell me what else I need. Noticeably absent is air tools. I have focused on tools that are not as expensive as the ones that are made by my employer. Most of my tools so far are Facom (French). This is not because I dislike US tools, but these seem better and priced cheaper than my employers tools at my employee discount. So, advice on tools that are the best bang for the buck rather than highest price is appreciated. Here is the list of what I have:
1/2" Facom socket set (ratchet, 10-19, 21-24, 27, 30, 32mm sockets, 6 &12" extensions & u-joint)
1/4" Facom socket set (ratchet, 5.5-14mm sockets, extensions, driver, & hex, torx, phillips, & slot bits)
1/2" 25-250 ft-lb sk micrometer torque wrench
Stahlwille open-end wrench set (6-20, 22, 24, 27, 30, 32mm)
Facom tongue and groove plier
Facom diagonal cutting plier
Facom long nose plier/cutter
Generic 4pc mini plier/cutter set
OTC 100 series Automotive multimeter (rpm, diode test, temp, frequency, and the usual stuff)
Facom Hex key set
6 pc Facom screw driver set (four slot, 2 phillips)
2pr Vise-Grip (needle nose & standard)
Ball-peen hammer
Klein wire cutter/stripper
Magnetic pick up tool
Bastard file
Pick set
scraper
snips
utility knife
SK 5 drawer mobile work station
