Go Back   Automotive Forums Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > Maintenance
Maintenance Discussion about maintenance issues.
Old 10-12-2003, 03:12 AM
rx3boy rx3boy is offline
Idle hunting problems
My R32 has a bad hunting problem at idle,Hunts between 400rpm may stall at times, then back up to 1000rpm then back down etc, whether it's hot or cold! I have played around with the idle screw and the tps, which has made it a bit better, but still hunts! Anyone have any idea's on what the problem may be! I have heard skylines have a lot of problems with the Air Flow Meter and O2 sensor. What problems and effect do they have if faulty? Any help would be appreciated!
Old 10-13-2003, 01:31 AM
RazorGTR's Avatar
RazorGTR RazorGTR is offline
Skyline Man
Check for vaccume leaks in any of the rubber hosing or boost leak in the rubber joins. If all that is cool I would look at either the TPS or air flow meter. It is a common problem and I have been through this a few times with different skylines. The AFM is a real problem.
You don't own a Skyline, then don't cry to me about it!
1992 Silver R32 GTR tickled to 450hp. - Sold when I left NZ in 2004
Arguing on the Internet is like competing in the special olympics. Even if you win, you're still retarded.
Never confuse kindess with weakness.
AF user guidelines, Please remember to abide by them
Old 01-18-2004, 07:01 PM
Ebola 33-t Ebola 33-t is offline
Re: Idle hunting problems
Mine has a real problem when the aircon is on, i think its because the motec computer doesnt allow for aircon affecting the idle speed.
Old 07-31-2004, 08:35 AM
Chip in Oki Chip in Oki is offline
I had the same problem with my 96 GTS-T and consulted on of my Japanese friends. He told me to spray down the screen on the air flow meter with carb cleaner on the screen, let it dry, and then bolt it back on. Never had the problem again. Hope this helps.
Old 09-23-2004, 10:26 AM
CrashGordon CrashGordon is offline
I wouldnt use carbe cleaner, It make plastic britle. I used a product called electric contact cleaner, and it wors pretty good.
"Diamonds, She'll pretty much have to"
Old 09-23-2004, 11:50 AM
RazorGTR's Avatar
Skyline Man
Generally with AFM's it is dry solder joints on the circut board inside them. 99.9% of the ones that are faulty that will be the case. I've had mine on the GTR rebuilt and have not had issues since.
