Old 10-12-2003, 12:00 AM
stangfreak7 stangfreak7 is offline
Send a message via AIM to stangfreak7
Extra Horses
How much extra horsepower will i get out of an E303 cam and a set of cobra rocker arms? would i be better to put on a new intake and heads first or go with the cam and rocker arms?
Old 10-12-2003, 01:44 AM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
probably about 20 hp
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 10-12-2003, 12:36 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: Extra Horses
Forget about the cam unless you are doing heads at the same time. You won't see more then a couple hp by just slapping a cam in there with no other induction mods.
Installing the E cam with .498" lift and Cobra roller rockers (1.7 ratio) would give you an approximate valve lift of .528". The stock heads and valves springs wouldn't fully compliment the extra lift of the cam. You may also float you valves at higher rpms without new stiffer valve springs.
My suggestion is do the heads and cam swap at the same time, then go for the new intake manifold.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
