Old 10-12-2003, 12:50 AM
Jay eS Iye's Avatar
Jay eS Iye Jay eS Iye is offline
Send a message via AIM to Jay eS Iye
removing/installing a transmission
ok i know the basics on what i need to do, but what tips can you give me?
also i'm curious how to support the engine while i remove the tranny. i know i need to put a floor jack under the transmission, but how do i support the engine?
hopefully if the engine comes in monday i can have the car driving by the end of the week wish me luck
The Civic is gone...
The Camry never ran...
The Chevy is here to stay...
The Ultimate Honda Engine
Old 10-12-2003, 01:27 AM
91civicDXdude's Avatar
if you're leaving the engine in the car, i've found that simply not removin the driver's side engine mount wont let the engine fall all the way down. that way, you can pull the tranny out diagonally and towards the bottom of the car to clear the input shaft, then pull it straight out the top once you've cleared the engine, or if the car is high enough, pull it straight out the bottom. A tranny doesnt weigh much.
Old 10-12-2003, 01:53 AM
H4Bangin's Avatar
H4Bangin H4Bangin is offline
Send a message via AIM to H4Bangin
ya just let it hang from the driverside mount
thats a sic ass table in ur avitar .i want one!!
Old 10-12-2003, 02:01 AM
HONDABOND HONDABOND is offline
Some advice, take out the whole engine! You will be soooo hapy you did... If you dont, remember this thread so you can come back in here and say "Seth was right"
If you leave the engine in then you will have to put the trany in at an angle.
I also recomend you drop the engine through the bottom of the car, this makes things WAY easier and it also prevents you from breaking alot of shit (Still, be carefull of the tps and so on) Take off your bumper and use the bumper suport to pick up the car (With a cherry picker) then set a piece of wood under the engine/tranny at the higth the motor/tranny would normaly sit at (Usualy a pallet cut in half does the trick nicley... If your car is lowered) then lift the car again and remove the header/downpipe, front crossmember and radiator. Once this is done set the car back down so the engine/trany sit on the pallet and unbolt all the mounts and disconect the wiring (DO NOT DISCONECT ANY WIRING FROM THE ENGINE!) There are four big plugs, just disconect them from the sub harness on the car and you will be a happy camper. Once all of this is done simply lift the car and tilt the engine forward slightly (MAKE SURE YOU DISCONECT EVERYTHING THAT HOOKS THE MOTOR TO THE CAR, spedo cable, coolant hose, throttle cable, clutch cable and so on) the engine will just sit on the pallet while the car is lifted into the air (If the car is realy low concider 1. taking off the rear bumper 2. puting the back tires on something STABLE) now that the engine is out disconect the starter, the splash gaurd, and all eaght (I think) bolts at the bell housing, when you install the new trany make sure to get a new clutch going on while you in there, easy to install but a bitch to get to if you know what I meen. To install a clutch simply remove the presure plate and flywheel (This is a bitch) install the new flywheel and presure plate and use the alighnment tool for the disc. A few points on the clutch install, NUMBER ONE-USE A HONDA MANUAL AND TORQUE TO STOCK SPECS! You could verry well grenade a clutch by not following those simple instructions. TWO, use a new pliot bearing! and THREE USE A NEW CLUTCH CABLE!
Anyway, thats just my advice (Putting in a new clutch while you are there already) Now then, install the new tranny the same way you took off the old one and torque the bolts to honda specs. Tilt the engien forward again and SLOWLY drop the car down on top of it (If you folowed my instuctions correctly it will go right back into place) hook everything back up and enjoy the new tranny/clutch.
Side notes, remember to take it easy on the clutch for awhile and please, please look out for that cherry picker! I stood up under it and rung my bell so fucking hard I was seing stars man...
White folk eat noodles too.
Old 10-12-2003, 02:09 AM
I know that last bit was alot to digest, but also remember to use new/rebuilt axles, axle nuts, and honda brand trany fluid ONLY.
There was something else, but I cant remember it right off the top of my head, I'll get back to it later.
Old 10-12-2003, 04:17 AM
thats too much work just to change a tranny.
oh, and regular motor oil works well in trannies, seeing as thats what my service manual recommends and what all my honda friends use.
Old 10-12-2003, 02:14 PM
Jay eS Iye's Avatar
Re: removing/installing a transmission
hell yeah i've heard you can get them online for a couple hundred bucks but i haven't looked. it'd be interesting to make like end tables weith honda blocks
ok so let the engine hang by the engine mount, do i need to disconnect anything tho, anything that when the engine hangs would be pulled too much? and should i be ok with regular 2 ton engine jacks, will those keep the car high enough to get the transmission from below the car?
and thanks for the advice hondabond, but i'm at school so i'll be doing this in my girlfriend's parking spot at her apartment area
Old 10-12-2003, 02:22 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
i disagree. if you pull out the battery tray, the engine and tranny will come right out.....rather than dicking around with trying to stuff the tranny back in with motor in place. i also find it easier to mount the tranny to the block when you have open space to work in.
i agree with seth except for putting in underneath. now that is too much work. shoot...it looked like work just to type is all
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 10-12-2003, 02:28 PM
amy@af's Avatar
REMOVAL:
INSTALLATION:
different strokes for different folks. hopefully that helps if you choose to go that route.
edit: all MT info is at http://www.binghamtonlife.com/manual...ansmission.htm
Old 10-12-2003, 03:06 PM
93weed_eater's Avatar
93weed_eater 93weed_eater is offline
Send a message via AIM to 93weed_eater
one word HELMS
Old 10-12-2003, 03:13 PM
amy@af's Avatar
Originally Posted by 93weed_eater
one word HELMS
ummm, thats where it's from. can dl the crx manual from this page: http://www.binghamtonlife.com/manual/manual.htm
the haynes sux. it's full of wonderful "consult your service manual" remarks. great manual...after you buy it, it tells you to consult a different manual
Old 10-12-2003, 04:04 PM
Yea, I got one of those haynes before I bought my helms... Cant find my helms thoe. The haynes is a pos.
I'll tell you what thoe, I have done the trany with the engine in the car, out of the car, pick out the top, droped in the top, pulled from the bottom, swaped in from the bottom and I'll tell you what, its alot easier to lift the car up than it is to lift the engine out... I speak from experiance.
Oh, make sure you know if you have an STD or DX because alot of the time its hard to tell (Unless you have a sun roof) I spent four days trying to install SI axles into my buddies "DX" going out of my fucking mind till greg pointed out that it was in fact a STD... Things went much smoother from there.
Old 10-12-2003, 08:35 PM
Jay eS Iye's Avatar
i have a chilton and I use the online helms that Ami posted, the chilton is for more convenience and helps most of the time, when it doesn't i go online
oh and i'm lucky, i can mark off one of those steps:
Drain the transmission fluid.... sigh...
Old 10-12-2003, 11:57 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: Re: removing/installing a transmission
i don't know if it's really all that different for an auto, but when we swapped out my old auto tranny for another one, we just threw some straps around the engine, hooked a chain to it, threw it over one of the trusses in the shop, and connected it to a chain winch and just lifted the engine a little bit to take the strain off of the mounts. Then disconnected the speedo cable and the wiring, took out the intake tube and battery, unbolted the bell housing, and the tranny mount, took out the axles and it came right out through the bottom. I think it took like a total of 3 hours in and out. But then I had a Honda mechanic helping out.
Empty Pockets Racing Member #1
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 06:32 AM
