Old 10-11-2003, 06:47 PM
newcat newcat is offline
Question Anti lock brake light and stuck in Park
I should have titled the post anti lock brake problem.
Thanks for any help! You could save our marriage
Old 10-16-2003, 11:12 PM
fordin K fordin K is offline
so what's the problem ?? if your anti lock brake lite is on, then your base brake systems still works. if it is stuck in park, then your brake pedal switch maybe adjusted wrong or connection loose. give more details..
Old 11-09-2003, 12:44 AM
ervinj ervinj is offline
Sometimes the sensor inside the rear housing gets dirty. If the light comes on and you don't notice a difference in the way it brakes you can remove the cover on the rear and spray clean the sensor with brake cleaner. This has taken care of the problem for me on several occasions.
ervinj
Old 12-13-2003, 04:46 PM
trukasaurus trukasaurus is offline
Re: Anti lock brake light and stuck in Park
I had this same problem on my 94 f150, under the hood is another fuse box, there is probally a fuse blown which will not let the vehicle shift out of park. The Ford owners manual does make mention of this problem. If you can't find it, let me know and i will have a look. Keep me informed. Good luck
Old 12-14-2003, 11:50 PM
Re: Re: Anti lock brake light and stuck in Park
Well you all may not believe this, but it was the cruise deactivation switch located on the master cylinder that was shorting out the 15 watt fuse. WOW, did that rack a lot of brains, but my husband was looking under the hood when I noticed the glowing red part and the brilliant man finally found the problem.
I appreciate ALL the advice.
Maybe this will help someone one day.
Thanks again.
Happy Holidays.
anti lock brake light/ touchy brakes junkowner M Bodies 1 08-22-2009 11:08 PM
alero rear brakes out.....ANTI-LOCK BRAKE light ON czechnate Alero 4 09-13-2005 12:20 AM
Hub-bearing and anti-lock brake light leel Century 2 10-11-2004 04:23 PM
Starting problems and Anti-Lock Brake light joscopar Intrigue 1 06-16-2004 02:15 AM
rear anti-lock brake light swjones Rodeo | Passport | MU 0 10-05-2003 05:15 PM
