| Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music. |
Problems with amp
Ok I hooked up all the wires, RCA inputs, remote turn on, ground and power wire. It turns on and everything but when I hook my subs up they dont work, now i can feel them move when they turn off and on but no music is being sent to them. Any ideas on what the problem might be?
Wait a minute, you mean to say a bottle of pop is bigger than your engine?? "Pain is weakness leaving your body" There is NO replacement, for displacement... 2007 Kawasaki ZX10-R S.E.
Re: Problems with amp
Are any lights on on the amp?
that movement you feel is most likely a small DC signal that the amp puts out when they turn off and on, which means the power is probably all hooked up correctly. You have the subout turned on on the headunit correct? On some headunits the sub rca output is off unless you actually go into the menu and turn it on. You might also have the subs wired to too low of a resistance which is sending the amp into protect mode. If that's the case you should have a "protect" light on on the amp.
'01 Black Sentra SE Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8 '05 Silver WRX STi Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials |
Re: Re: Problems with amp
BTW, it's a Panasonic CQ-DF200U...if anyone could help me out with how to get it putting out to my amp please help...
How are you wiring the amp? I know when I tried to bridge my amp to run two 10s on one channel it wouldn't put out any power and the LED went off. The amps was only rated for a certain amount of Ohms and I think once bridged the subs were no longer in that suggested area, so the amp wouldn't run them. Just an idea.
that would be my guess too ...... the load from the speakers is too great (too low of an impedance) than the amp can handle.
No no, it's not my wiring. It's a 2 channel amp, I've got two subs, wiring them directly up to + & -. I had a few friends suggest things to do. I got another question, I press a button on my cd player and it will say like, LED on or off, what's that about??
ok i dont know if you have the same one as my freind but it should be close there should be a button or option in the menu somewhere called shbd set it to boom rather than off.
My guess is you wired it out of phase A, or you have it on a low pass crossover or you are crossing over all the lows
Re: Re: Re: Problems with amp
if they were wired out of phase they would be moving normally, the signals would just be cancelling each other out and the sound would be weak. It is possible that the sub amp is set on high pass and the output on the headunit is on low pass, so you're actually not sending any signal at all to the subs
No, it's something with the head unit or the RCA cable, which was a brand new one. I spliced an old RCA cable and hooked the wiring up to the speaker wires, plug it into the amp it works, I dont want to leave it this way but there is nothing wrong with the amp, or my wiring, it was either the RCA cable or something with the head unit. I'll leave it this way until I have more time to worry about it.
k well i have a big problem with my amp ... its a cheap blitz 2400 watt amp ... and i got it from a FRIEND ...but when i got it worked ... and now the protection light stays on and nothing is goin to the subs ... what is wrong with my amp ? ... is it blown ? ... i checked the fuses ... i tried it in other cars ... double checked the wiring ... everything ... so if someone can tell me whats wrong i would really be greatful ... thanks from kunkowkillaz
Dont bring back old threads, start new ones if you need help.
As for your amp check the sub wiring, you might be running at to low of an impendance. Or check the power wires and sub wires you might be shorting the wires out.
Cant remember who posted it but if you see it give yourself credit Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota. Cardomain |
