Hi, hope someone can help.
The car is 99' 528i SE Auto, and all three lights came on at the same time when I was driving the car, so I assume that the problem must be related. The Speedo, mpg dials also stopped working. I've checked the automatic transmission fluid, and it is low, but I know that there is a proceedor to toping the resiviour up and I'm not sure what it is ?. Any advice would be extremely welcome. thanks in advance.... |
check the fuses
Check the fuses.
It is an electrical issue, 100%. Later
Re: Transmission Light, ASC Light, ABS Light all on at the same time
What was wrong with you car? |
Your abs unit probably has an thermic fault and shuts down when hot. you can test it by heating/cooling the contoll unit (on the hydralic unit). You should take it too a BMW dealer to get it changed (need's programming)
Re: Re: Transmission Light, ASC Light, ABS Light all on at the same time
Thank you so much. I am dropping my car off today at the BMW dealer. I will post more when I get it diagnosed and fixed. From a phone conversatoin the BM dealer said it could be a wheel sensor and that it would be like 300 if that. I was trying to have it fix oustise the dealer so I don't get screwed, but o well....... |
