Old 10-10-2003, 11:41 PM
TheWire TheWire is offline
Please help with cluster info... i only have 4 days
ok,
I have a 90 civic dx 4dr (it shows august 89 on door)
and am lookng into upgrading my gauge cluster to 1 with a tach.
I got 1 already from a 89 civic lx and the tach didnt work and it wasnt rounded like mine was.
Well i found two edm clusters with 155mph speedo and 9.5k redline tach
1 is from a 89 crx and has only two plugs on the back like my curent cluster but the other is from a 90 civic and has 3 plugsand a bunch of extra lights like "alb" and "gas", the 3rd is a small blue plug what is this plug for? will either of these work for me?
plz help me
Old 10-11-2003, 01:07 PM
Exclamation Please help... i only have 4 days
BUMP
Come on now, no one here knows this info?
Old 10-11-2003, 01:53 PM
toronto pimp toronto pimp is offline
cant help you with the clusters you have, but if 4dr is the same size as hatchback just find a cluster from an si and it will plug right in i believe.
- Eibach Sportline Springs
- KYB GR2 Gas Shocks
- The usual clear lenses/hyperwhite bulb
Next: Front/Rear lower tie and upper strut bars
Old 10-11-2003, 10:11 PM
Re: Please help... i only have 4 days
Originally Posted by TheWire
BUMP
As quoted above
Old 10-12-2003, 08:50 AM
91EF3ZC's Avatar
91EF3ZC 91EF3ZC is offline
AF Premium User
Send a message via AIM to 91EF3ZC
Re: Please help with cluster info... i only have 4 days
ok,
plz help me
The ALB light is anti-lock brakes, it will not light up. The gas light won't work either, unless you install a fuel sender in your tank. You will need to get one from a 90-93 integra. The small blue plug is for the speedo.
If your car is an 89 and the cluster is a 90-91, you are going to have to re-wire it and figure out what wire does what. And try to get a wire schematic. only way to do it.
Visit my EF page:http://www.pbase.com/luv2hover/91_civic_&page=all
Old 10-12-2003, 10:23 AM
fredthedragon's Avatar
fredthedragon fredthedragon is offline
Send a message via AIM to fredthedragon
if you need a wiring schematic i know i've seen some of the admins post pieces from one, i have one for a crx i could dig up if you want or you could try your haynes manuel. lemme know if you need me to dig that up.
I'm no street racer nor do want to be, my goal is a fun car... that leaves SUVs in the dust.
current car: red 90-civic-STD-hb
with dx trannie, ecu, shift knob, & rear seats.
i hate my vynil seats.
p.s. i am once again with computer, please forgive the one year leave of absence.
Old 10-12-2003, 12:12 PM
Ya id realy appreciat it if u could!!!
Thnx
Old 10-12-2003, 12:22 PM
question for 91EF3ZC
ok i put a gauge cluster with only the two plugs on the back from a 89 civic lx and the tach didnt work... is this just the wireing or is it just not compatiable.
so if my car is technicly a 90(august 89) why dont i have the blue plug 4 the speedo.
and y have people told me it works without the blue plug....
Im so confused
Old 10-12-2003, 04:09 PM
91dx 91dx is offline
AF Cutter
Im so confused
On your wireing setup the tach is a blue wire and it's on the far left side plug. It'll be the 1st, 2nd or 3rd wire i'm pretty sure. Make sure it's there and it's connected to your distributor in the correct place and it should work unless it's just lose. Push down on it when your sitting at an idel and then rev a lil and jiggle it. That's what the problem was with mine. lose wire believe it or not and I beat my brains out trying to figure out wtf it is. If you need a scamatic I made my own but I'm not sure about the lx cluster or whatever. Should be simliar cause it is on my 89 crx and my 91 civic dx. If u need more help holla. peace
Old 10-12-2003, 08:37 PM
Re: Re: Please help... i only have 4 days
Originally Posted by LadyNRedSi
http://www.binghamtonlife.com/manual/manual.htm
it's for a crx but the wiring should be the same, it's official haven't had a chance to look at it myself but hope it helps.
Old 10-12-2003, 08:45 PM
ok sorry that's a little complex mabey you could ask LadyNRedSi
