Old 10-10-2003, 05:46 PM
timmie2508 timmie2508 is offline
Cold Air Intake Question
Ok im getting a Hotshot Cold Air Intake System. The filter is going to be below the engine so that when it rains water is going get into my filter. What happens when water gets into the filter? Does it effect the engine or just wear down the filter quicker?
Old 10-10-2003, 10:54 PM
D[X]P's Avatar
D[X]P D[X]P is offline
Send a message via ICQ to D[X]P Send a message via AIM to D[X]P
i heard it messes up your car and cant start it
Failure is only the opportunity to begin again more intelligently.
Old 10-10-2003, 10:58 PM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
Re: Cold Air Intake Question
it depends on how much water gets in. If enough water gets in, then your pistons shatter into dozens of pieces when they encounter tremendous hydraulic pressure within the cylinder! Just don't submerge the filter completely and you should be fine.
Another concern that you should have if you're going to be getting the filter wet very often is that the water mist passing through the filter can bring with it contaminants that will harm your engine. Salt mist is particularly bad.
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 10-12-2003, 02:55 PM
454Casull 454Casull is offline
I suppose you could build a baffle out of spare tubing if you feel teh need...
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
