Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 10-10-2003, 04:59 PM
Soyo's Avatar
Soyo Soyo is offline
Send a message via AIM to Soyo
engine rebuild
ok on a 91 non-turbo what would an engine rebuild consist of? I'm still trying to learn everything about rotaries so fill me in, oh and what kinda price should I expect to pay for parts and labor?
1989 RX-7 TII --- Just got rebuilt and street ported
RB 3" dual exhaust, BNR stage 1 modified factory turbo, FCD, S-AFC II,
720cc secondaries, Aftermarket Turbo inlet duct w/K&N, Hawk HP+ pads
HKS Blow-Off Valve, Stainless brake and clutch lines
Old 10-11-2003, 07:53 PM
SG-supra7 SG-supra7 is offline
If you do the labor your self, an base engine rebuild will cost you about $700.
If you do a master rebuild (that means replaceing more parts, like corner seals, oil pump chain, ....) It will cost you about $950 or so.
But if you pay someone to rebuild your motor, or buy a new one, and send in your core, it will cost about $1200 +
If you are going to pay someone to do it, I suggest talking to Kevin Landers at rotarresurection.com He is a great guy to deal with, and does good work.
But I would suggest that you do not rebuild your own engine, without learing alot more about it, because I've seen alot of people rebuild there own engine's, and they didn't make it threw break in before they started eating apex seals.
Old 10-12-2003, 10:30 PM
Soyo's Avatar
well something I need to know is like what parts would be replaced in a master rebuild cuz I know most engines is like pistons, rods, cams, etc. but rotary don't have that so someone fill me in
Old 10-14-2003, 04:46 AM
CHINRX CHINRX is offline
Re: engine rebuild
water seals,oil o-ring,stationary bearing,rotor bearing,full gasket set,cornel seals w/spring,side seals w/springs,apex seals w/springs, this is basically what you will put in and thats depend on who will do the engine but i recomend that the engine is already open to put in everything new,and do some porting is already open.
Old 10-14-2003, 04:48 AM
Re: Re: engine rebuild
[quote=CHINRX]water seals,oil o-ring,stationary bearing,rotor bearing,full gasket set,cornel seals w/spring,side seals w/springs,apex seals w/springs, this is basically what you will put in and thats depend on who will do the engine but i recomend that the engine is already open to put in everything new,and do some porting is already open.
