Old 10-10-2003, 01:23 PM
Mister_Ed Mister_Ed is offline
Fuse Box
This is probably a stupid question. Just started using my mother in law's 87 LeSabre. The turns signals don't flash, they just stay on solid. I'm assuming it needs a new flasher, but I can't find the fuse Box and I don't have the owner's manual. Where's the fuse box??
Old 10-12-2003, 12:40 AM
tman's Avatar
tman tman is offline
Pimpin' ain't easy
Send a message via AIM to tman
Re: Fuse Box
most likely underneath the dash, just look around, you should find it.
Old 10-13-2003, 07:40 AM
pcv pcv is offline
The flasher unit will be under the steering column to the right side of the column. It will be clipped and secured out of sight. You might have to use a flashlight to find a silvery unit. It will be the same as the four way flasher unit but they never put them next to each other for us to find.
Good Luck.
NOTHING LIKE AN OLD CAR.
Old 10-13-2003, 08:43 AM
Re: Fuse Box
Good Luck.
Thanks! Appreciate the help.
Old 10-13-2003, 08:46 AM
Re: Re: Fuse Box
Thanks. For the record, I found out that the fuse box is behind a plastic trim panel to the left of the steering column. The access clips are hidden by the driver's door, when it's closed.
