Old 10-10-2003, 09:40 AM
90gs's Avatar
90gs 90gs is offline
Send a message via ICQ to 90gs
Headlight bulb question
whats the K rating for a 2002 cavaliers stock headlights?
i have these aftermarktet blue ion 9006s (in my integra) that i got from kragen and my friend with a cavalier wants them but im not sure if it'll work in her car... kragen only sells them in 9006. i swapped them out a while ago cuz its kinda rice but its what she wants..
Old 10-10-2003, 02:55 PM
studballs studballs is offline
2000 and up use 9007 bulbs...not sure if 9006 will work or not
Later
Chad
Old 10-18-2003, 04:55 PM
s8kimo's Avatar
s8kimo s8kimo is offline
Send a message via AIM to s8kimo Send a message via MSN to s8kimo Send a message via Yahoo to s8kimo
Lightbulb well, sorta on topic
i bought the 9007 blue heads..and i have no idea on how to replace the factory. does anyone out there know how or where to find a manual on the web that discusses a step by step procedure. any help would be greatly appreciated.
thanks
Old 10-18-2003, 08:05 PM
sweetwhiteCAV sweetwhiteCAV is offline
Send a message via AIM to sweetwhiteCAV Send a message via Yahoo to sweetwhiteCAV
take off the splash guard and then pull light bulb out from behind the assembly, and put the new one in, be careful not to touch the glass part of the bulb...
P.s. get yourself a Haynes repair manual, it well worth the $15
Old 10-18-2003, 08:27 PM
s8kimo's Avatar
headlights
they don't have a repair manual out yet and the splash guard isn't the only thing in the way.....unless your talking about the bottom one..not the one above the bumper.
thanks...i'll try it.
Old 10-18-2003, 08:38 PM
what year is your cavalier? if its 2002 or less, then the haynes manual is the same...
Old 10-19-2003, 12:17 PM
s8kimo's Avatar
bulb
alright i'll check it out i have a 2002
Old 10-21-2003, 09:14 AM
RABarrett RABarrett is offline
Here's a concept. Go to a parts store and check what bulbs fit in both cars. They will have the necessary info since they sell these bulbs. No muss, fuss, or bother. Ray
Old 10-21-2003, 09:18 AM
P.S. the K rating is the temperature at which the bulb operates. It determines the color of the bulb at temperature, whether white or yellow. The higher the temp, the whiter the light. Not knowing the lens tolerance for the vehicle in question, it is difficult to determine, but more importantly, is the bulb correct for the vehicle. Determine the type, then determine the temperature tolerance for the lens. Ray
Old 10-21-2003, 09:55 PM
s8kimo's Avatar
thanks
thanks for the info..however i installed them 2 days before you sent your messages.
Old 10-22-2003, 04:37 PM
Sniper0860 Sniper0860 is offline
I have a 99 cavalier and it uses both the 9006 and the 9007, one for low beams and one for the highs.
Old 10-23-2003, 03:59 PM
s8kimo's Avatar
02 cavy
just uses one the 9007
