serpentine belt installation for 1999 Blazer
How difficult is this?
Anyone have a diagram and instructions? |
Drive Belt Replacement
Removal Procedure Install a 3/8 inch drive wrench on the drive belt tensioner arm and rotate the arm counterclockwise. Remove the drive belt. Slowly release the tension on the drive belt tensioner arm. Installation Procedure Route the drive belt over all the pulleys except the drive belt tensioner pulley. Observe the drive belt routing for the vehicles without air conditioning. Observe the drive belt routing for the vehicles with air conditioning. Install a 3/8 inch drive wrench on the drive belt tensioner arm and rotate the arm counterclockwise. Install the drive belt over the drive belt tensioner pulley. Slowly release the tension on the drive belt tensioner arm. Inspect for the drive belt being properly installed on the pulleys. Avoid mis-positioning the drive belt by one or more grooves. Confirm for the proper drive belt size and the correct drive belt routing by observing the location of the fix pointer and the index marks on the drive belt tensioner. With a new drive belt installed the fix pointer should align within the indentation on the drive belt tensioner. With a used drive belt installed the fix pointer should not align past the index mark.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again? Got all the certifications 25 years ASE Certified Master Technician GM WCT Yea..I work at a DEALERSHIP....got a problem with that? Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality) This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video PM Me for details |
Just had one installed..$78 at dealership.
Re: serpentine belt installation for 1999 Blazer
I have a 1987 chevy Blazer s10, the serentine belt comes off every few months. Does anyone have a diagram (Picture) of how the belt goes on properly? This would sure help.
Also where is the tension pully? I am new to this stuff. |
I change the one in my 98 Blazer every year. The part is $35 at Advanced auto. Very easy to do, you don't have to take the belt completely off.
Put in the rachet into the tensioner, push counter clockwise. Remove belt off tensioner. Remove old tensioner, put in new tensioner. Put rachet in tensioner, push counter clockwise and hold it while you place belt over tensioner with other hand. |
Re: Re: serpentine belt installation for 1999 Blazer
There should be a diagram of the proper routing of the belt on your radiator cover on the top. If you are looking at your engine, the tension pully should the the pully to the right of your alternator. The belt should come off your alternator and loop under the tensioner.
