Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 10-09-2003, 05:33 PM
delSol86 delSol86 is offline
Weird Tread Wear
For some reason my tires keep wearing on the inside. I have been told by the tire company that the alignment is off. I got it aligned and i was still the same. I was told the suspension was bad. I went to a suspension specialist and they said it was fine. Does anyone know?
Old 10-09-2003, 06:56 PM
whiteracer whiteracer is offline
Send a message via AIM to whiteracer Send a message via Yahoo to whiteracer
Re: Weird Tread Wear
Camber. Is your car lowered?
Name's David.
Old 10-09-2003, 11:38 PM
akina_speedstars akina_speedstars is offline
What kind of car do you have?
What modifications have you done?
Your inner tire wear seems to be associated with high negative camber so the inside edge of the tire is touching the ground rather than the entire width of the tread. If you got the wheels aligned but didn't replace your wheels, then tire wear will be even. Since the inner side wore out faster, that area will still wear down, but evenly with the rest of the tire.
Old 10-10-2003, 10:24 PM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
You could also have too much toe in/out. My car is dropped about 2" all around but I'm running 2.5 negative front and 1.8 negative rear camber and my tires are wearing fine event with 20'ish autocrosses on my tires this year.
Last year I had 1.5 negative front and 2.2 negative rear with 30 autocrosses and my soft Falken Azenis lasted all year with tread to spare. Even with 15K street miles on them.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 10-11-2003, 12:16 AM
I have a '94 delsol and it was lowered when i bought it. From looking at the suspension the guy didnt buy any coilovers or springs, i think he had them cut. Only the front is lowered to, about 1.5". Does this mean anything?
Old 10-12-2003, 06:10 AM
Dezoris Dezoris is offline
Mod for life
Send a message via AIM to Dezoris
Ha all your events evened out the wear.
I bet if you did not run those events the inner wear would be more biased.
M.Sanew - AutomotiveArticles.com
Old 10-13-2003, 12:11 PM
Civic Mod
Actually my current set of 205/50x15" Azenis on 15x6" stock wheels are wearing evening too. Never ran them on an autocross
Autocross Help Page
Buy my Civic parts!
