Old 10-09-2003, 03:45 PM
tommyboy42609 tommyboy42609 is offline
what should i do? 1 or 2 amps?
Hi im getting new component speakers put in along with 2 12" JBL subs...i was wondering if i should get a seperate smaller amp to power the infinity kappa 60.5 component speakers...
so waht do you guys think?
1 big amp to power the components and subs
or
1 small amp and 1 medium sized amp
here are the specs on the components:
Sensitivity 90 dB
Frequency Response 45 - 21k Hz
RMS Power Range (Watts) 2-90
Peak Power Handling (Watts) 270
thanks alot for any help/opinions.
Old 10-10-2003, 12:11 AM
No-Townhustla No-Townhustla is offline
2 amps homie you could run your components of the same amp but i really wouldnt, you risk blowing out your mids and it will just sound better with it own amp...................................GETHIGH
Old 10-10-2003, 12:17 AM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: what should i do? 1 or 2 amps?
2 will be a better choice, both for power purposes, tuning, and if you ever want to upgrade it will make it much easier.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 10-10-2003, 08:22 AM
ssjwizard ssjwizard is offline
Send a message via AIM to ssjwizard Send a message via Yahoo to ssjwizard
definatly two. for you subs you want to run on low frequencys depending on your prefrence and setup generaly only frequencys below 45hz i have mine set to about 65-70hz and lower myself it just sounds better that way i think. 2 amps so you can use low pass filter on subs and to match it up so you have the right amout of power going to the speekers and subs on a single amp will be hell
