Old 10-09-2003, 03:18 PM
Po Pilot Po Pilot is offline
Send a message via ICQ to Po Pilot Send a message via AIM to Po Pilot
Aux Fan Mod
For those of you who want to drop the temp at which the aux fan comes on this article will help you out!
http://www.angelfire.com/my/fan/CTS.html
Old 09-21-2005, 08:26 AM
rmendez rmendez is offline
My cherokee is 96 4.0l My aux fan only came on with the a/c, with the a/c off never came on. I replace the sensor in the thermostat housing but still the problem any other recomendation.
Old 09-21-2005, 09:37 AM
89ltd 89ltd is offline
Re: Aux Fan Mod
your the man, I'll do it tomorrow. I already have the 180 stat in but have the fan rigged to come on steady in the summer as soon as I fire it up. It doesn't over heat now, just runs a little hotter than I would like it to. rmendez, does you 96 get hot enough to make the fan come on?
Old 09-21-2005, 01:24 PM
edmaude edmaude is offline
best thing to do it just run an override switch. fan will run stock at 220 w/ switch off and on demand when you turn it on. I ran this on my 96 for a while, but the real reason I was running hotter was that my fan clutch was worn out. now w/ new fan clutch i never even need to use th override since the temps stay lower
Old 09-21-2005, 01:26 PM
_Dark_Flash_ _Dark_Flash_ is offline
it's pretty rare when my fan comes on
'89 Cherokee aux. fan relay location? msok Cherokee 3 01-16-2005 09:33 PM
Aux. Fan StealthZ32 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 4 05-17-2004 01:56 AM
Xtera 2003 Rockford Fosgate Aux Input Mod Question? 2K3IS300 Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 0 04-22-2004 03:58 PM
Anyone know how to test the aux fan/switch.... mistervelasco 3 Series 2 03-10-2004 10:18 AM
92 325ic aux fan prob hills6 3 Series 0 08-06-2002 10:49 AM
