| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
Is an LS swap not worth doing?
Is it worth getting an LS swap for my 96 hatch and then going turbo in a year or just go b18c1 and leave it stock.
[size=1/2]96 Civic CX Hatch 1.6 Non VTEC Full length CAI Custom Catback Exhaust Short throw H&R stage II springs Tokico Illumina adjustables front upper,rear upper,rear lower tie bars ST front and rear sway bars BOOSTED![/size] |
IT's all in what kind of performance you need and for what use.
For a daily-driver, i'd go all-motor, all the heat generated by the turbo and the additional lines may not be too good for grocery-getting purposes. Whatever you decide, i got an engine for you. b18b, b18c gsr, i got b16b type-R civic, b18c teg type-R, and 99+ b18c SPEC-R (type-r engine that's track-ready). I also have b20b obd1 and obd2.
do the ls turbo. the ls is a great engine to turbo and relatively cheap compared to the gsr swap. also the ls can handle up to 12psi PROPERLY tuned. you can turn down the boost for going around town. also the turbo is cooled down by coolant/water and oil so it should be the same temp as the rest of your engine bay in the first place if not then not much more. alot of people use turbo cars as a daily driver.
IMO i would go with the LS Turbo. Lower CR than the B18C and you could boost more in stock purposes.
2004 Sonic Blue Ford Ranger XLT 2001 Liquid Grey Metallic Ford Focus ZX3 1995 Integra GS-R - Parting out |
Re: Is an LS swap not worth doing?
You think LS turbo on built LS would be better than crvtec b20 (frankeinstien) built turbo motor??
Re: Re: Is an LS swap not worth doing?
You can make decent numbers out of an LS/turbo motor, but if you're going to go through the hassle of sleeving it and throwing in rods and pistons (I hope you were kidding by recommending SRP pistons for a high boost setup) go with the vtec head, as it flows better and your car will make more power as an LS/vtec. Here's a stock LS motor with a blockguard, an SC61 at 14 psi, and a hondata.
If you're going to bitch and say "no, the LS makes more power because of no overlap!!!!!!!!1" just don't. Heres a stock internal GSR motor with a 3MM headgasket (8.3:1 compression) ARP studs, and the same precision SC61, but this is at 11 psi, again with hondata. ![]() That overlap sure seems to be holding his setup back, I think he should switch to a vtec head
Thanks for the advise guys.... its all helping me make my future decisions!
but what c/r should i make the block for say about 15 psi (street) and 20 possible more at the track.... once again thanks for all advice
what size turbo should i run for 15-20 psi on a fully built LS.... for street/strip??.. any recommendations? thanks alot
...Smokn91HB, what is the HP goal you have in mind...before you choose a turbo, you really need to have the end HP goal, then you can figure the flow rate needed to reachthe goal, and the approperate boost (psi). There's of course more to it than that, that's the basic verison...still, a HP goal is the first starting point when choicing a turbo, you need to know this to figure out the flow and boost needed to reach the goal, among other things. Last edited by eckoman_pdx; 12-26-2003 at 05:15 AM. |
I will try to start out with about 300 HP or soo but i want to end up with maybe 450 or possibly close to 500
no way dude, im just not buying this. an ls motor is much easier to turbo and has much more boost potential. i am very, VERY skeptical of your printouts...8.3:1 with 11psi?!?! also, dyno charts are not the final line, good so you can do some research over the internet and find a couple "dyno" charts to bolster your case...as eckoman said they are 2 different dynos and 2 different cars, different guys doing the testing...i dont buy it. dyno charts are just like the bible...its says one thing, but everyone tries to prove different things with it...no where in the bible does it say its alright to judge others but people find passages to back this up...just as youre doing with the charts. may not be a good analogy but you get my point...ill believe that shit when i see it...
1997 Honda Prelude Base 18G Turbo - 8 Psi GReddy EVO Catback 1995 Honda Civic LX Bone Friggin' Stock |
smokn91HB, first I'll take your question, since this thread is to help you out....okay...now, you want to start with 300HP, but end up with 450-500...well, chances are you'll need a different turbo to get to each level, uless you want to push one maybe to the point where it's extrememly ineffiecent at both sides (300 and 450). So, keep that in mind for there. That being said, if you want SERIOUSLY want to boost it that high, you will NEED RE-SLEEVE IT...PERIOD. Don't mess around with any cheap thing like a "block gaurd," it will not hold up under the boost you will need to run to achive that kind of power, AEBS makes some damn good sleeves.....the rods will have to go also, use crower rods (not the econo crower rods). These are very strong rods, and will be well suited for your purpose. Also, get some good pistions, JE Pistions or Weisco makes good pistions. I read somewhere thar JE Swain Tech Coated Pistions are better, I know that's what robbie potts used for his set-up. But you'd have to call and find out the exacts, as to whether that's true or not. Also, re-gardless of whether you LS/Vtec it or not, You will need to Port and Polish the head...a full race port and polish would be good with that kind of output goal. Re-working the quench area will also help, and this will eqaul more complete combustion (and less chance of denination). New Valves springs, and re-tainers will be needed..ferrera makes some good ones, and crower makes some good springs and re-tainers, though there titanium ones are spendy. A VERY IMPORTANT part of breaking 500HP is the fuel system delievery...don't botch that up....for that kind of power, you will want a stand alone fuel computer, and the injectors will be BIG with a HIGH flow rate....robbie potts used a Federal Mogul Speed Pro stand alone fuel computer and 1,000cc injectors...this is the same set-up used by Papadakis and Kubo (when she raced Hondas). As for what flow rate you'll need, I don't have all this stuff I need to calcutale with it, it being the holiday's and all. I really don't want to give a wild guess on something like the needed flow rate. As for the PSI needed, 13 should get you 300HP, give or take. But for 450-500HP..we're talking in the 20's, like 24-28 most likely, depending ont he set-up. At this much boost, DON'T SKIMP COSTS, unles you like re-building blown motors....It'll figure out some number later when I get back after the holidays.
Now, Quote:
