Old 10-08-2003, 07:30 PM
Mojoe Mojoe is offline
91 CRX HF Axles for B16A swap
One of the automotive parts stores in my area has Si axles with 23 spline outboard joints. Can I use these axles instead of replacing my kunckles and hubs? If so, will they be strong enough or would I be better off changing the hubs, knucks, 26 splines all the way? The car is going to be primarily a commuter but will be raced occasionally.
Old 10-09-2003, 01:34 AM
hondaracer hondaracer is offline
Re: 91 CRX HF Axles for B16A swap
They are pretty strong all the way and if your going to be mostly commuter don't worry about them. The only way so far I've seen half shafts break is by when people were dragging and popping the clutch for launching at the green light at a strip. You can race on them no prob, just don't pop the clutch when you do or any other time, it also breaks down the clutch too when you do it.
Old 10-09-2003, 06:45 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
the crx si axles will not fit in a b16 tranny, your gonna need the axles that come with your swap, or check out www.raxles.com for some custom built ones.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 10-10-2003, 01:26 PM
Jeff C's Avatar
Jeff C Jeff C is offline
you can find a 90-93 integra ls intermediate shaft and use the corresponding axles. you can buy the teggy axles from advance auto for $60ea with a lifetime warrenty.
Btw, seeing as how you have an hf, you might need to upgrade your huds to 89-91 Si ones. I am not completely sure on that though.
-1989 Honda CRX Si, B18A Pic FOR SALE
-1998 Honda Accord EX Sedan 5spd
-1981 Chevrolet Silverado, shaved and bagged Pic
Old 10-11-2003, 03:34 AM
Will the axle still have to be modified when using the Teg ls intermediate shaft or is it bolt on from there on out? And your right about the hubs & knuckles.
Thanks for all the replies
Old 10-11-2003, 03:12 PM
Jeff C's Avatar
no, thats the thing. if you use the teg ls intermediate shaft, then you dont need to do that hybrid axle crap. you can just go to advance and pick up the ls axles.
Old 10-12-2003, 09:43 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: Re: 91 CRX HF Axles for B16A swap
You have to change your hubs, the HF's have pencildick axles, and hubs to match, get the teg's. You
They will physically fit inot the tranny, but you can't use them because A. they are too long, and B. they don't use a halfshaft like the B series, you can however mix and match inner and outer joints back and forth to create retarded hybrid axles that you could have just bought, I am babbleing, I'll stop now.
want to know the pin locations for the vtec harness for b16a swap in '91 si madchildz '88 - '91 Civic | CRX | Wagon | Shuttlee 6 05-17-2005 06:17 PM
What axles for b16a? please help HontegraGSI Let's get Technical! 7 03-26-2005 05:16 PM
shift linkage for b16a swap blufke '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 04-01-2002 08:27 AM
Axles for b16 Swap ricodemus '71-'87 Civic | CRX 8 03-07-2002 10:18 PM
$$ for b16a swap? CRX586 '71-'87 Civic | CRX 15 02-28-2002 08:42 PM
