Old 10-08-2003, 03:49 PM
JDM00CivicEX JDM00CivicEX is offline
Help with gauge cluster
I have a 2000 civic ex coupe 5speed and my speedometer wasn't working. On this forum members told me that i needed to replace the vehicle speed sensor, which i did and it is still not working. I took my car to autozone and they read the ecu codes, and one of the codes showed that the speedometer is not working, and that the ecu thinks that the car is not moving at all. Is there anyway to fix the speedometer without having to replace the whole gauge cluster??????
Old 10-08-2003, 10:02 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
It has to be a problem with the VSS or the wiring between the VSS and the ecu. As long as there is a signal from the VSS the ecu will be fine it does not rely on the actual speedometer moving, it relys on the VSS. Try to see if any of the wires are damaged. And make sure that the VSS is installed correctly.
Old 10-09-2003, 12:07 AM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
also make sure that the gears are lined up on it. Try resetting the ECU and the code will go away and hopefully your problem will be solved.
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Old 10-09-2003, 12:45 AM
Re: Help with gauge cluster
how do i make sure that the gears are line up on it? and also i reset the ecu twice, turn the car on and 3 seconds later CEL comes back on and same error codes. Also where can i get all of this checked out, because i have spent over 300 dollars trying to fix it and still no luck and i just want to fix this asap.
Old 10-09-2003, 03:37 PM
whtteg's Avatar
Re: Re: Help with gauge cluster
Originally Posted by JDM00CivicEX
...... Also where can i get all of this checked out, because i have spent over 300 dollars trying to fix it and still no luck and i just want to fix this asap.
Honda is the best option IMO
Help with gauge cluster pin location on 70 Chevelle SS northput21 Chevelle 1 02-20-2007 01:51 PM
2000 caravan with gauge cluster problems mikeypooh1 Caravan | Voyager 4 06-02-2005 09:35 AM
93 Blazer S10 - Need help removing gauge cluster 93BlazerGyrl Blazer 4 03-24-2005 05:53 AM
i need wiring help 4 gauge cluster... Dastreetracer '88 - '91 Civic | CRX | Wagon | Shuttlee 0 02-25-2005 09:48 AM
PLEASE HELP Instrument Gauge cluster DEAD [email protected] XJ6| XJ8| XJ12 | XJR 0 08-11-2003 08:44 AM
