Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 10-08-2003, 12:17 PM
grncivicdhr's Avatar
grncivicdhr grncivicdhr is offline
AF Premium User
Send a message via AIM to grncivicdhr
need some help.
has anyone ever changed the alternator on there 240? i'm used to v8's in 70s muscle cars and i've never seen a part this ridiculously cramped. is there any advice anyone can give as to how to do this without liftin the engine or some crazy shit. i can barely touch the thing, let alone get any tool near it to remove it.
Old 10-08-2003, 01:01 PM
J SPEC SilEighty's Avatar
J SPEC SilEighty J SPEC SilEighty is offline
Send a message via AIM to J SPEC SilEighty
when we replaced it in my friends 240, it was a bitch to get to. We couldn't get anywhere near it from above like you said. We had to remove the engine undercover and pull it from below. your also going to need to remove the lower cooling fan shroud to get to a couple of the bolts to remove the alternator. If you have access to a lift or can rent one for a couple hours, I would recommend doing that. It is a PITA laying on the ground under the car trying to get this thing off. If I ever have to replace the alternator again, I will definately go to the base and use the lift.
Old 10-08-2003, 04:48 PM
AF Premium User
thanks for the help, i'll be gettin it off next wednesday...by the way, how difficult was it to put on? thats more of what i'm worried is gonna be a bitch to do.
Old 10-09-2003, 09:10 AM
Re: need some help.
yeah it was definately harder getting it back on. It's easier if you have somebody else to help you hold it in place while you put the first bolt in. Once you get the first bolt or 2 in though, then it's just a matter of figuring out how to get your arm in those hard to reach places to put the other bolts back in. good luck
Getting some detail done, need some help FireFromTheGods Exterior | bodykits | Lighting 0 10-06-2004 11:00 PM
need some help resizing some pics for my sig twdz28 Camaro Discussions 2 09-02-2004 01:50 PM
Need some help findin some parts. slammina98blazer Blazer 5 03-02-2004 08:03 AM
Need some help from some one that can make custom PE parts. Jon MW Car Modeling 1 10-20-2003 10:33 AM
i need some help on some rims jays87 Tires and Wheels 10 05-07-2002 11:32 AM
