Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 10-08-2003, 11:48 AM
joe321 joe321 is offline
oil pressure
It seems that I have an oil pressure light at low RPMs after the engine has warmed up. Its been doing this for a while; I've recently changed the oil and filter are new and I know its still there So I figure it could be either a failing pump or pressure switch. I would like to check the pressure with a gauge but I don't know the procedure to do this. My best guess is to screw the gauge into the oil pump pressure relief valve but I am not sure.
Second, if it happens to be a pressure switch were are they located and how are they changed. The haynes manual give the pressure measurements but doesn't outline the testing nor do they discuss the switches.
Thanks.
Old 11-15-2003, 02:53 PM
yale329 yale329 is offline
Re: oil preasure
Unless you take a manual oil pressure test, please take my advice until you find the problem. Put a can of STP oil treatment in for safety sake. Could be a main bearing, or oil pump. Better safe tan sorry.
Old 11-17-2003, 09:31 PM
Scatch! Scatch! is offline
Re: oil preasure
The pressure switch is at the "back" (toward the firewall) of the engine. Test it, and I'm fairly certain you will find your culprit.
little or no oil preasure ATMA3Weapon Silverado 3 06-03-2008 09:54 AM
96 Ram 3500 Diesel looses oil preasure hillbillyfan Ram Pickup | Ram SRT10 1 10-13-2007 08:53 AM
Oil Preasure all the way to H Jeepster4.0 Grand Cherokee | Grand Cherokee SRT8 1 12-03-2006 08:26 PM
how do i replace a oil preasure switch chuck8587 Camaro Discussions 4 04-28-2006 02:48 PM
oil preasure up and down like crazyneed help! 3KGTOUTLAW 3000GT/Stealth 7 07-26-2004 01:28 PM
