Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 10-07-2003, 06:25 PM
BadAzz240's Avatar
BadAzz240 BadAzz240 is offline
Send a message via Yahoo to BadAzz240
Rough Idle...
Ok, I have a 92' 240, at idle the car is really rough. Sometime it will just die. Normal driving seems to be ok except when i shift it kinda jolts or if the clutch is in long enough for it to get to idle it may die like i said before. Ive checked all the basics(Plugs, Loose Wires, Vacum Leaks, etc...) and cant find anything. First thought was maybe a knock sensor but, I did some research and looks like it might be a so called "IAA" valve or and "AAC" valve. Kragen, Car Quest, etc... dont know what I am talking about but I went to nissan and talked to the guy there and we found an AAC valve that I can order but its like 200 bucks. Any of this sound familiar to you guys. I want to make sure i know what it is before i go buying something i dont need... or if there is another fix... Any suggestions may help.
Old 10-07-2003, 09:46 PM
mynismo mynismo is offline
yada yada yada
Send a message via AIM to mynismo
Re: Rough Idle...
clean your air intake valve, and intake piping. then up the idle by taking a philips screwdriver and there will be a spot on the passenger side of the engine where you stick in the screwdriver and adjust the idle. bring it up a couple hundred rpm (after you clean the aiv). if that doesn't solve it i'd say take it to the dealership
438whp / 373tq - 11.9 @ 126
Old 10-07-2003, 11:18 PM
BadAzz240's Avatar
Yea, I have cleaned all that before...so there shouldnt be to much buildup in there, I actually took my whole throttle body off before cleaned the whole thing with carb cleaner and a toothbrush, put it back on with a new gasket... But ill check it all see whats up.
2.7 high and or rough idle hauck Intrepid 6 02-25-2012 11:46 AM
89 Mustang LX, rough idle and runs terrible. Ericdano Mustang Problem Diagnosis 2 11-07-2009 02:14 AM
96 Cutlass Supreme w/ Rough Idle, but drives good chrisluna Cutlass Series 1 09-17-2009 07:29 AM
Help with 97 Villager rough idle dscott1838 Villager 12 05-09-2009 09:34 AM
Rough Idle Mayathebee Cougar 1 03-22-2009 08:23 PM
