Old 10-07-2003, 06:18 PM
LethalGT LethalGT is offline
Send a message via AIM to LethalGT
Question EGR or ECM Problem?
I ran a diagnostic on a check engine light and it gave me a code 32 which is an EGR or ECM problem. How do I know which one is giving me problems? Also could one of these problems relate to my last post about the truck losing all power when I use my turn signals? BTW its an 89' Silverado with the 350.
Old 10-07-2003, 08:22 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: EGR or ECM Problem?
Code 32 is usually caused by the valve or solenoid.
Check the passages by pulling up on the EGR diaphram (becareful its HOT) while the engine is running. If the engine stumbles and almost stalls the passages are good.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 10-10-2003, 08:10 AM
I did what you suggested GMMerlin and it did stumble the engine. any other suggestions? Thanks for the input.....
Old 10-10-2003, 08:34 AM
I have still been trying to diagnose an electrical isssue, so here is what I possibly could have narrowed it down to. Yesterday it died on me again as soon as I used my left turn signal, complete power loss. I coast into the driveway. Its dark by this time so when i open the door, no door light comes on. The truck has absolutely no power, as if the battery is dead. I pop the hood and just barely touch the positive starter wire and the door light comes on and the truck has all the power back. So I'm guessing part of my dying problem could be due to the positive starter cable? I noticed about 10inches from the positive battery post, the starter wire looks like it has possibly been burned a little with a part showing bare wires and even may have been spliced together. Thanks for any help.....
Old 10-10-2003, 12:17 PM
GMMerlin's Avatar
I know stuff
Replace the cable. That should solve that problem.
As far as the EGR..if the engine stumbles I would go with a valve and solenoid.
GM WCT
PM Me for details
Old 10-10-2003, 02:32 PM
GMMerlin,
Thanks for the advice. I'm going to replace the EGR Valve, I can almost guarantee its the EGR Valve with all the symtoms its giving me. What brand should I look at getting & is there anything I should know before replacing it?
Old 10-10-2003, 02:41 PM
GMMerlin's Avatar
I know stuff
I would recommend using a GM valve and solenoid.
I have experianced too many problems with aftermarket valves.
There is a part number on the valve, you will need that to get the correct GM replacement.
GM WCT
PM Me for details
95 STS Defective ECM (52) & Internal ECM problem (109) zengel442 STS and STS-V 2 11-18-2008 06:53 PM
1981 - ECM problem, fuel pump problem Adrian12 Deville 0 09-09-2006 07:09 AM
Ignition, Exhaust, Or ECM problem ??? 86TA Money Pit Camaro Discussions 3 05-06-2004 11:45 AM
ECM problem or air flow sensor? wtmason Off-Topic 2 04-30-2004 12:31 PM
1995 Chevy Cavlier ECM problem jadams Cavalier 0 09-08-2002 02:23 PM
