Old 10-07-2003, 04:11 PM
rex oner rex oner is offline
Send a message via AIM to rex oner
my rex pics
just thought i whould share..
well its been under for a bit but i got my rex back.. its not nice looking but it gets the job done..
new ls motor..
with dc sport headers
short ram
mugen style chiped ecu
matrix muffler w/custom cat back..
high flow cat
and str block spacer
ebay short shifter w/type r style knob
adr 16's in the back of the car
tell me what you think!
M T R LESS CRX!
Old 10-07-2003, 04:17 PM
more..
M T R LESS CRX!
HondaCivic4358's Avatar
HondaCivic4358 HondaCivic4358 is offline
Send a message via AIM to HondaCivic4358
nice. how much was the motor and what year of teg did it come out of?
Old 10-07-2003, 04:26 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
Re: my rex pics
itz ok.....looks like a regular rex to me....nice engine....
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 10-07-2003, 04:49 PM
well i got a whole 1990 integra ls for 1,000 witht he motor already pulled out ..the car ran a 14.5 at the track.. and i got it of a friend so i thought it whould be good.... no!(ex friend now)
it needed new block(studs were striped),water pump,freeze plugs(some one took then out),oil pan,headgasket,oil pan gasket,head studs,plug wires,cat,crank pullie,and like 3 or 4 more seals.. so it was siting at the shop for a 1 1/2 months the swap alone cost 1,800(mounts,shift linkage,wiring,and labor).. plus i got every thing from honda so i spent about 3,000-3,500 in all!!
but its out now!
M T R LESS CRX!
Old 10-07-2003, 04:57 PM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
it looks good with the b18a1 in it, did your car or the teg run the 14.5, if it was the teg then be sure to post your time when you go to the track, it should pull about a 14 or high 13s considering the weight difference
KoRnSaQ
Old 10-09-2003, 01:09 AM
it was the teg that ran 14.5 .. but i put an under drive pully and high flow cat on too.. so im hoping that with my traction problems i know i have.. it will hit a 14 flat or better..
as long as it is better then 14.3(what a stock mustang gt runs) i will be happy
M T R LESS CRX!
Old 10-09-2003, 10:16 AM
91civicDXdude's Avatar
you tell me how in the hell an integra ran a 14.5. It had to be spraying.. i've seen stock GSR's run mid 15s with 40 more horsepower.
