Old 10-07-2003, 02:19 PM
senna95 senna95 is offline
Hesitating '95 Bird
I've got a 1995 Firebird with a 3.8Li/ 5 speed. It' got about 97,000 miles. It is hesistating under acceration at all speeds. There isn't any smell like a plugged converter. I have replaced the center coil pak (cylinders. 2 & 5) three times. Platnium plugs and wires were changed at 65,000 miles.
I also repaired the main harness problem (wires rubbing against stud on block next to firewall) that it had at about the same time. When I replaced the coil paks before I at least had an engine error code. I'm not recieving one at this time. Any help would be appreciated.
Old 10-07-2003, 03:12 PM
BlkCamaroSS's Avatar
BlkCamaroSS BlkCamaroSS is offline
Send a message via AIM to BlkCamaroSS
I bet you need a rebuilt tranny. Our 95 did the same thing, and it was great after the rebuild. It's because it's so worn that it's slipping under acceleration, and therefore not accelerating as fast with the pedal down...
2001 Camaro SS #2239 of 6332
1/4 mile time: 13.575 @ 105.55 mph, 60' time: 2.276
307.1 rwhp, 330.1 rwtq = 353.2 hp, 379.5 lb ft torque
Options: SLP Front Grille w/ SS Center Logo, 17" ZR1 Chrome rims, 6 speed, Hurst Short Throw Shifter, Monsoon 500 Watt Sound System, T-tops, 1LE Performance Suspension
Mods: Holley PS Air Filter, SLP Air Box Lid w/ Mr. Ed's pipe fix, SLP CAI, SLP Bellows, SLP LM, SLP Y-pipe, SLP 160 Thermo, SLP Temp Module, SLP STB, KBDD SFC
Old 10-07-2003, 03:20 PM
hesitating Firebird
The engine hesitates while in neutral and parked. If engine RPM is slowly raised, the hesitation is not as noticeable but is not practicle for driving.
Old 10-07-2003, 03:33 PM
FAPhoenix's Avatar
FAPhoenix FAPhoenix is offline
Send a message via MSN to FAPhoenix
My guess is a problem in the fuel delivery system. Possibly a plugged filter, injectors or faulty fuel pump.
Really bad spark plugs may also cause this.
Old 10-07-2003, 03:42 PM
Re: Hesitating '95 Bird
I just replaced the fuel filter in May because I was smelling fumes from under the car. The filter was leaking from the inlet side. I still do smell gas when getting out of the car every once in a while but don't really see any leak. I'm not sure if its unburned fuel. The odor is usually pretty strong.
Old 10-07-2003, 06:39 PM
FAPhoenix's Avatar
Well if you keep smelling gas is it possible there is a tiny leak in the hose? That would cause a lack in vacuum which might lead to hesitating.
(Pure speculation here).
If it was your tranny slipping it would be broken by now The tranny went in my truck, I felt it start slipping and by the time I was 4 blocks to the tranny shop it was pretty much dead.
As well, I think only the clutch can slip in a standard and that would be smoking everywhere if it was slipping.
Old 10-16-2003, 01:59 AM
AnotherBreedRacing AnotherBreedRacing is offline
Send a message via AIM to AnotherBreedRacing
try this do a fluid change on everything run fI cleaner threw it and check your throttle pistioning sensor change fuel filters and ther maybe water in your gas tank but that should take care or it let me know what happens i have ran into this so many times a knock sensor coudl be at fault to
Old 11-16-2003, 03:59 PM
89birdowner 89birdowner is offline
i am 99% sure it is your mass airflow sensor and/or dirty intake, my car does exactly the same, mine was quoted at $500 for fix of an 89 bird
