Old 10-06-2003, 11:27 PM
crx hf crx hf is offline
RPM gauge freaking out
Well when i have the car in neutral or its just sitting at a stop the needle jumps from 1k to 1,200 but you cant hear the engine reving up.Could it be that my dizzy is going out.I was told that when your dizzy is going bad you get these symptoms.Also i have a hard time starting my car when the car is cold.
Old 10-07-2003, 12:28 AM
BullShifter's Avatar
Re: RPM gauge freaking out
Your idle is too high to begin with. Adjust it correctly then see where your at.
Old 10-07-2003, 09:47 AM
feelsfast feelsfast is offline
Send a message via AIM to feelsfast
Re: Re: RPM gauge freaking out
if there is no change in engine speed I would check your distributor. Its probably your ignitor which is inside the distributor. I would swap out the distributor if I were you with a known good one and see if it helps and then if you feel like it you could just swap out the ignitor its pretty simple with the distributor off the car.
Yes my car is slow!
Cruise control freak out cobraprince 3000GT/Stealth 13 03-23-2009 10:41 AM
RPM / Tachometer freaking out Ltl_red Problem Diagnosis 7 02-11-2009 11:25 AM
97 oil guage freaks-out at low RPM oneandthesame Explorer | Explorer Sport Trac 1 02-06-2005 08:19 AM
