Old 10-06-2003, 10:54 PM
frolio2986 frolio2986 is offline
Carburetor backfire??
I recently rebuilt the top end of my jeep: new pistons, rings, valves, reworked head. It runs but the carburetor hesitates upon acceleration and backfires often with flames. I have set the valves numerous times only with the same results. What would cause flames to come out of the carburetor?
It seems to me that for flames to come out of it, the plugs would have to spark while the intake valves are open, and that doesnt seem like it could happen. I know it could also be the intake valves not seating properly but i had the head reworked and the valves ground.
Old 01-04-2004, 01:09 AM
jeepguyxj jeepguyxj is offline
Re: Carburetor backfire??
check your firing order maybe you got two wires backwardes. did that once and flames throught the carb. or timming problem. hope this helps
Old 02-12-2004, 12:11 AM
supernova70 supernova70 is offline
I had that same problem with my nova.when you get a studder and a backfire that means your running to lean. you will most likely need to jet your carb up 1 jet at a time until the problem is fixed. very simple!takes 10 min. good luck
Old 02-12-2004, 10:19 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Re: Carburetor backfire??
It is running too lean, but its not the main jetting. Its the accelerator pump that is not working. It creates a lean condition in the intake manifold which makes the hesitation you feel.
This lean mixture can be ignited from an intake valve.
Fix the accelerator pump so it provides a bigger squirt of fuel when you step on the accelerator. Dont worry about the valves. The problem will go away when the pump is adjusted.
Old 02-14-2004, 01:30 AM
good call magicrat,I forgot about that.frolio, check out what magicrat said first. if that doesn't work then check your jets. oh yeah, if your carb has float bowls, check those too.make sure the gas is no lower than the bottom of the port.
88 K1500 5.7 sputtering, backfiring occasionally dirkhood C/K 17 01-30-2011 11:11 AM
1974 Dodge 360 W100 Backfires jb77 General Discussion 0 08-28-2010 07:23 AM
96 GMC Jimmy black smoke, backfires, Timing? corhey88 Jimmy 38 01-31-2010 03:29 PM
93 suburban backfire cjttmyers Suburban 13 07-12-2009 10:46 AM
Carburetor backfire?? frolio2986 General Discussion 1 10-08-2003 01:54 AM
